Likes Likes:  1
Results 1 to 14 of 14
Thread: Floor boards
    20+ Posts
    Apr 2016
    Bartlesville Okla
    Default Floor boards
    2003 Goldwing still has driver pegs. Want to install floor boards, also down and forward a bit. Do floor boards work on trikes and what do you like?
    Thanks Joe
    Jun 2010
    Indianapolis, In.
    If you install weight bearing foot fairings you can remove the pegs and rest your feet on them. Lowers your feet and is much more comfortable. Also install a Kurt heel rest to assist using the foot brake
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    20+ Posts
    Apr 2016
    Bartlesville Okla
    What would be weight bearing foot fairing, I have the Champion conversion. Is this something that can be bought?
    100+ Posts W3JNP's Avatar
    Nov 2016
    Reading, PA
    These are common in this area. I have them and am pleased with them.
    http://wingstuff.com/products/2624-k...w-heel-shifter
    2008 Stallion
    Reading, PA 19606
    Jun 2010
    Indianapolis, In.
    Quote Originally Posted by refuelman View Post
    1st the word Kurt in my post was meant to be Kury as in KuryAkyn.
    Google Champion trikes to see if they have weight bearing foot fairngs
    Patriot Guard
    Was a LEO
    May 2011
    San Angelo
    I don't believe they do. If you look at the photos on their site they call these things "Lower Accent Panels"..... I don't see how a person could even use them as foot rest at all let alone be weight bearing..
    2015 GL1800/Roadsmith HTS1800
    Jun 2010
    Indianapolis, In.
    Quote Originally Posted by Gold Rush View Post
    Since I don't know, I can't say yea or nah so, maybe a call to Champion would answer the question
    Patriot Guard
    Was a LEO
    Jun 2010
    Indianapolis, In.
    Comment from a owner on another forum:
    "I have the Accent Panels on my Champion and really like them. The two extra large yellow running lights in the front help on being visible. Plus, I am 6'2", 290lbs and the foot peg location on the wing was causing me to get cramps in my legs. I took the pegs off and put my feet on the Accent Panels when RIDING ONLY. I do not step on the panels to mount or dismount, just rest my feet on them."
    Patriot Guard
    Was a LEO
    May 2011
    San Angelo
    Good info!!! Thanks for "Birddogging" that for us!!
    Sep 2016
    Lake Havasu City Arizona
    Default Csc floor boards
    Floorboards will Definately not support "ANY WEIGHT" They are made to dress up your ride only. Look underneath and see how flimsy your floorboard mounts are. That in itself will answer your own question. ��
    80+ Posts
    Sep 2014
    SE New England
    I have a Lehman Trike kit on a 2012 GL1800. The trike has weight bearing Aqua Shields and I installed the Kury floor boards with the toe heal shiffter as well. The trick here is on the Lehman Kit there are 2 different shape small brackets that replace the OEM supports that support the Aqua Shields attaching them to the OEM Peg mounting brackets. These brackets allow space for the driver boards to be mounted while still maintaining the weight bearing features.
    I use the Kury boards to mount and dis-mount the bike. Champion which mow has purchased Lehman may have these addition brackets that would fit the Champion Trike. I can give you the Lehman Parts numbers if you wish. It may be worth a call to Champion to see if they would fit.
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    If referring to running boards, some manufactures make them weight bearing and some don't.
    Just and FYI ... be aware that some running boards make clutch fluid changes, evaporative control system inspections, and coolant changes more labor intensive. On some, the running boards must be removed or pulled loose in order to remove the lower center cowl. According to Honda, some of those services need done every 12,000 miles.
    50+ Posts
    Aurora Indiana USA
    Quote Originally Posted by W3JNP View Post
    That's the ones I have. Now I need to get the matching ones for passenger.
    100+ Posts Dude's Avatar
    Sep 2015
    Jacksboro
    I have the Kury floorboards and heel toe shifter as well and really like them. Roadsmith makes forward comfort controls for the Goldwing.
    http://trikeshop.com/shop/product/726/comfort-controls/
  1. Floor Boards...???
    By BOXX3R in forum Harley Tri Glide
    Last Post: 08-04-2016, 02:26 AM
  2. Kuryakyn floor boards
    By bjacmarsh in forum Honda Trikes
    Last Post: 09-27-2014, 09:10 PM
  3. Passenger floor boards
    By woody in forum Harley Trike Conversions
    Last Post: 07-12-2014, 12:14 AM
  4. Floor Boards
    By sonney in forum Honda Trikes
    Last Post: 12-15-2010, 09:35 AM
  5. floor boards
    By samw in forum General Discussion
    Last Post: 07-05-2010, 12:31 PM
