Likes Likes:  1
Results 1 to 7 of 7
Thread: Aero 750 Motor Trike Suspension Adjustments
    10000+ Posts skuuter's Avatar
    Apr 2010
    Estill Springs, Tn, USA
    Default Aero 750 Motor Trike Suspension Adjustments
    Any other Honda Aero 750 Trikes here from Motor Trike ? Just curious about Your favorite Set-ups. Been Ridin'/Tinkerin' with the Wife's Trike this week....right now I've settled on:
    Air Shocks: 20 lbs air
    Rear Tires: 20 lbs air
    Front Tire: 38 lbs air
    Coilovers: One adjustment above the softest
    I "assume" there aren't a lot of these Trikes on here, but would appreciate Your opinions if possible.....THANKS...:wtg:
    700+ Posts ultraboy's Avatar
    Dec 2008
    NW Indiana
    Default Re: Aero 750 Motor Trike Suspension Adjustments
    Well skutter, I'm picking up one of these for my daughter this weekend in KC. We're riding 600 mi. two-up on my HD trike, and Reenie will ride the Honda back home. To start out, I'll surely use those numbers of yours! Thanks!
    "Beer is Proof that God loves us and wants us to have a good time."
    Apr 2010
    Quote Originally Posted by ultraboy View Post
    Great...we can compare notes later if you decide to "re-adjust"....
    300+ Posts Calman's Avatar
    Jun 2009
    Whortonsville, NC
    For the past year I've been happy to run 22-24 lbs of AP in the rear tires with 41 lbs of AP up front. After 17K miles the rear tires are just beginning to show signs of wear. I changed out the factory front tire 10K miles ago and it looks like it's good for another 10K.
    I normally run 30 lbs of pressure in the airbags since I have a heavy trailer hitch for my hitch rack plus I have about 20 pounds of "stuff" in the trunk. When GF is aboard I run the AP up to 45 pounds.
    Apr 2010
    Quote Originally Posted by Calman View Post
    THANKS for Your INFO.....have You ridden it with 30 lbs in the air bags with just the Rider onboard...if so, what was Your impression....I rode this one with 15 to 45 durin' my Trial Stage.....
    Jun 2009
    Whortonsville, NC
    When I add the hitch rack I boost it from 30 to 40 lbs. If the trunk were to be empty and no trailer hitch (like it was when I got it last year), I found 30 pounds of AP to be too stiff. I found the rear end would "bounce" instead of roll. And that and sometimes cause the rear end to "slam" when returning to earth and cause the air bags to deflate.
    Apr 2010
    THANKS.....:wtg:
  1. Motor Trike Suspension
    By Judge Judy in forum Honda Trikes
    Last Post: 08-27-2021, 02:56 AM
  2. Shadow Aero with Motor Trike
    By smilinjohn in forum Motor Trike
    Last Post: 06-30-2012, 06:54 PM
  3. Motor Trike suspension
    By Judge Judy in forum Motor Trike
    Last Post: 01-18-2012, 07:59 PM
  4. Replies: 4
    Last Post: 12-09-2010, 10:52 PM
  5. Suspension on gl1500 motor trike
    By wdy41 in forum Motor Trike
    Last Post: 08-01-2010, 05:53 PM
