ADSavarese6Marc HNew Member Introduct...New member from FL
ADSavarese6ADSavareseNew Member Introduct...New member from FL
ADSavarese6Phu CatNew Member Introduct...New member from FL
ADSavarese6trike ladyNew Member Introduct...New member from FL
ADSavarese6Uncle FesterNew Member Introduct...New member from FL
ADSavarese6rhino 2New Member Introduct...New member from FL
Likes Likes:  2
Results 1 to 10 of 10
Thread: Radiator
    250+ Posts
    Dec 2010
    oly,wa
    Default Radiator
    Hello
    thought I would try to wake up some hibernating help. I need to replace
    my radiator. for those that have replaced theirs, is there a sequence to
    follow that will make the repair go more smoothly. thanx in advance
    Dragon
    300+ Posts
    Signal Mountain Tn
    Hello
    Dragon
    I haven't done it and hope I don't have to. I have looked at what might be involved in doing it. The parking brake cable runs under the radiator crossways. It appears that it would need to be disconnected some place. There are some screws visible on each side of the radiator but it is difficult to see what might be securing it at the top. Even thought I don't plan to perform this task, I would like to know what is involved in case I do at some point.
    100+ Posts Las Vegas Biker's Avatar
    Dec 2010
    Las Vegas, Nv USA
    Default Radiator
    Hi Chuck,
    Sorry to hear you have to replace it. I am on my third one.As you know I'm not any good at that kind of stuff. Richard told me to check the cap first in the trunk. He says a lot of leaks are coming from that. Good luck with it.
    Are you planning to go to Deadwood again? I will be there. Hope to see you.
    Terry
    250+ Posts
    Dec 2010
    oly,wa
    Hi Terry
    I haven't planned rides for 17 yet. I just had hip replacement and they say
    when I feel better I can have the other one replaced so I am just waiting
    to see how things go. were you able to get your lights fixed yet.
    Dragon
    Try to cross it @https://www.rockauto.com/en/catalog/
    250+ Posts
    Dec 2010
    oly,wa
    Hello
    I have a question or two . does everyone's a/c compressor come on when you turn on the fan.reading the ford manual it says the compressor is turned on in all but one heater mode.HEAT. manual says the a/c comes on to dehumidify the cabin air when defrost is used. but if the heat mode is used the compressor is turned off. do we have a
    heat control unit hidden somewhere if so where is it. doesn't make sense to me to have the a/c compressor come on when I only want fan heat. should also add to the mpgs.
    Dragon
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    My compressor only comes on when I turn the right knob to the "C" position. Rick
    Stallion #378
    Suzuki Burgman 650
    300+ Posts
    Signal Mountain Tn
    Hello
    Dragon
    If you are reading from a Ford manual, they are probably addressing the operation in a Ford car. This would help keep the windows from fogging up in a car.
    200+ Posts
    Feb 2017
    Arp, TX - USA
    Hello
    Dragon
    Dragon,
    The radiator fan will ONLY come on if you turn on the a/c by turning the "C" knob to the on position. As there isn't a vent selector on a Stallion the fan will not come on with heat without activating the a/c compressor.
    250+ Posts
    Dec 2010
    oly,wa
    Good morning
    thanx for the replays, I found out my problem was with the
    knob, it turned and made a clunk like it was turning the switch but was not doing anything so the compressor was on
    whenever I turned on the fan. I like simple problems like that and yes I discovered it by accident when trouble shooting.
    Dragon
  1. Running the trike with no radiator
    By speedyxjs in forum Home Built Trikes
    Last Post: 10-03-2015, 12:27 AM
  2. radiator hoses
    By Dragon in forum Stallion Trikes
    Last Post: 10-02-2015, 09:02 PM
  3. Radiator fan won't kick on
    By gunny2426 in forum Stallion Trikes
    Last Post: 08-10-2015, 06:26 PM
  4. Leaks on radiator
    By Backdraft in forum Stallion Trikes
    Last Post: 11-02-2013, 06:58 AM
  5. radiator?
    By ratrodney in forum General Discussion
    Last Post: 05-29-2013, 07:56 PM
