hogmemberisold3Phu CatGeneral DiscussionHow many carry spare headlight bulb...
ADSavarese5Phu CatNew Member Introduct...New member from FL
ADSavarese5trike ladyNew Member Introduct...New member from FL
ADSavarese5Uncle FesterNew Member Introduct...New member from FL
Davep3KoolbreezeHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
Davep3rhino 2Harley Tri GlideTRI GLIDE AIR FILTER QUESTION
Davep3DavepHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
ADSavarese5rhino 2New Member Introduct...New member from FL
ADSavarese5ADSavareseNew Member Introduct...New member from FL
hogmemberisold3cScjhbGeneral DiscussionHow many carry spare headlight bulb...
hogmemberisold3hogmemberisoldGeneral DiscussionHow many carry spare headlight bulb...
Likes Likes:  700
Thanks Thanks:  56
Page 30 of 33 FirstFirst ... 20 21 22 23 24 25 26 27 28 29 30 31 32 33 LastLast
Results 581 to 600 of 651
Thread: 88 blazer trike
  1. #581
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    I played with the welder for a while today.
    first on a 15a 120 outlet. Worked well for the thinner stuff but started to trip the breaker on thicker plates. switched to 220. worked great. I was even able to make some OK welds.
    I'm not used to holding the filler wire. First when I ended a weld I put the rod against my stomach, now have a 2 inch burn, 2nd and 3rd I placed the end of the hot wire on my legs
    I'm learning the hard (hot) way
    The torch head is adjustable to different positions. It also came with a foot pedal (just on and off) but I have issues with my feet. It also comes with a button on the torch. I like that since the foot pedal for me is not going to work.
    On 220 it welded 1/4 inch angle to1/4 plate. I did a crappy weld but the welder was able to do it and more
    I was working on another small metal art thing and was trying to tig weld a some pliers put it was turning out like crap. I finally realized I forgot to turn the Argon on.
    I have a lot more practice to do
    tomorrow I plan to look at the pinion angles on the trike again.
    Thank you
    Bob
  2. #582
    Sep 2014
    Moneta VA
    not good yet but better
    Wont even show you how bad I did on then thinner metal.
    I will get the hang of it at some point.
    Until I do I cant finish my headers
    Thank you
    Bob
  3. #583
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    All of the tig welders I follow on u-tube seem to be humble people....you are learning why! LOL I will probably be staying in the beginners category, but it is an enjoyable skill to try to learn!
  4. #584
    Sep 2014
    Moneta VA
    I have played with the TIG some here lately, Wife and Son have Covid so I have to isolate also.
    At home more than normal.
    I have tig welded a few things and its great! A lot cleaner.
    Still not doing well on the thinner metal though.
    It does make the small "art" things I want to do easier
    Thank you
    Bob
  5. #585
    Sep 2014
    Moneta VA
    I need to start thinking differently. Now that I can do some basic TIG some of the projects I do would turn out a lot better if I incorporated some TIG welded aspects to them
    Thank you
    Bob
  6. #586
    Jun 2016
    milnor n.d. usa
    there is a guy. does a lot of stainless steel art work...u-tube is pacific art tig welding..you might give him a look. .I am starting a tubular type of intake for some chinese webers so will be trying to tig also....I have some silicon bronze rod that i may try to use on tube to flange joints
  7. #587
    5750+ Posts BillR's Avatar
    Aug 2015
    Gloucester, VA
    Quote Originally Posted by Fowler View Post
    I always liked your "art" projects. Bring 'em on.
    Bill
    R I P MANDY
  8. #588
    Sep 2014
    Moneta VA
    I am rethinking my exhaust again. Still going with square but how I connect them may be different.
    I have been doing a little practicing with the TIG. I love that welder.
    My Granddaughter wanted a Kunai knife for Christmas. She wanted a plastic fake one. I did make a few of them for her and I bought her one.
    I also made her a real one. This is terribly off balance but its a wall hanger.
    The blade is a small section of leaf spring I shaped and heat treated in my forge
    The handle is some rebar I had around (and I tig welded it to the bladed before heat treatment)
    The guards are old dragon fly coat hooks that I cut the tails (hooks) off
    Sorry cant get the picture to turn the right way
    Thank you
    Bob
  9. #589
    30+ Posts AdvenJack's Avatar
    Feb 2019
    Gulf Coast, Florida
    At Your Service
  10. #590
    Sep 2014
    Moneta VA
    Hey guys,
    I just started looking at Trike Talk again.
    I have been concentrating on other thins for a long time now.
    I ended up having to retire due to medical issue.
    It's hard to work on the trike or anything with these dam braces I have to wear and the issues i have but I am slowly getting back to it.
    For the longest time I did not do much of anything because of the pain but I finally come to realize that I just have to do things anyway because if i don't I will just waist away.
    They have me on pain meds that also make things hard but again I need to get back into things.
    Anyway enough of that.
    I shortened the frame some and took away the big seats. For now I have an old lawn mower seat on it
    I did make my square exhaust I wanted but I still have to weld up the seams, its just tack welded for now. I need to use my TIG welder to do it but I stopped learning on that also while I was dealing with things.
    I need to figure out how to weld under neath the trike upside down. Im not the best at upside down welding and its not easy for me get down like that anymore
    I will get some pictures posted soon
    I have made a number of other things, things that I could make on a table and did not require me to crawl around. I will post some pics of them also.
    Thank you
    Bob
  11. #591
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Glad to hear you're still among us Bob
  12. #592
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Good to hear from you Bob.
  13. #593
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Hey guys,
    Welcome back..Bob….Nice to hear from you again…👍👍..
    2019 Tri-Glide.......
  14. #594
    Jun 2016
    milnor n.d. usa
    Glad you are back Bob! Looking forward to some content here on homebuilts. Have been working on a trike project myself, medical issues also, so slow going.
  15. #595
    600+ Posts TomyJ's Avatar
    May 2016
    Hemet, Ca. USA
    Default Bob's Back
    Welcome back Bob, I too have been down with medical issues. (broken left hip) so between the Trikes build and the partial enclosing of my 56 x 12 ft carport, almost ready to be walking with a cane.
    JakeJacobsen@Pinterest.com
  16. #596
    Sep 2014
    Moneta VA
    here are some pics of the Trikes
    The square exhaust and seat.
    Everything is tack welded for now
    The battery box and where I am welding the 2 half's of the frame back together
    With my braces on I have a hard time pushing the gas pedal. So on my VW Trike I 3D printed a hand throttle. I am on design version 10 now.
Size:  1.01 MB Name:  IMG20230828185329.jpg
    Thank you
    Bob
  17. #597
    Sep 2014
    Moneta VA
    More work on battery box
    Me
    Thank you
    Bob
  18. #598
    Sep 2014
    Moneta VA
    My daughter got married in the woods of our property.
    She had asked me to build her an arch and put it on a trail
    I ended up in the hospital and got a later start on it.
    I built this while having braces on my feet/legs and a neck brace (and on some good pain meds)
    I built it for it can be disassembled and moved around
    Cant find a pic of it setup in the woods on the trail
Size:  984.1 KBName:  20210426_144136.jpg
    Thank you
    Bob
  19. #599
    Sep 2014
    Moneta VA
    I found one with my granddaughter standing in it
    Thank you
    Bob
  20. #600
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    great job bob
  1. Happy Birthday Trail Blazer
    By Papa Zook in forum General Discussion
    Last Post: 12-07-2016, 02:39 PM
