I was planning to get a bottle from the same place I get my others from.
But was wondering how big of a bottle I should get.
Never Tig welded before
Thank you
Bob
I guess it depends on future projects....if one time deal with headers and not much else...I'd think about buying a Q.
Looking at demurrage every month for a big bottle sitting around gets old....I have paid for ox/acy demurrage for 50 yrs...retired now ....small projects only ..Q ox/with propane Q argon that's it for me.. If you get into a lot of tig I would go big and lease. ....the Q bottles get empty fast. probably a long way of saying, there is no right answer....
My ox/acy sit around a lot not used. But I plan to do a lot experimenting with the Tig so I will get the big bottle. At lease for now.
I have seen some tig welding art on line. I want to be able to do that one day
my flow meter should be in today. If it comes early enough I will go get a bottle of Argon. I assume the meter has a standard thread but I want to have it before I get a bottle
My welder is delayed though
Thank you
Bob
my welder came in today. I was not expecting it for a few weeks.
I'm modifying the cart my mig is on to have a 2nd level for the Tig
I picked up a 150cf bottle. The next size bigger they had was a 300cf. The bottle was just to big for my cart.
Thank you
Bob
Now have at it! the only thing that seemed strange to me about tig was that I had to make a conscious effort to move ahead, with respect to stick and gas welding.....Maybe the more vertical torch angle with tig.....anyhow, when puddle width is your desired bead width ... time to move forward.....maybe this will not be a problem for you.....good luck!
i still need to get some filler wire and figure out what tungsten rod to use.
Also the flow meter I purchased does not fit my new tank
I did build a 2nd level onto my welding cart for the Tig
Thank you
Bob
that looks like a standard argon regulator... which is what you want for tig,,
we use TIG Welding Tungsten Electrodes 2% Thoriated (Red, WT20) 10-Pack (3/32") https://www.amazon.com/Welding-Tungs.../dp/B013KZNLGG
I ordered some red and some blue
Thank you
Bob
so now I need to get some filler wire
for the first welds I was thinking about using these 1/4 metal plates I have. They are big enough, heavy and I have 3 of them. 1 for my son practice on, one for me and 1 for a friend
They go on the bottom of a server/switch racks
As I said I have never Tig welded before so I was thinking something thick would be easier at first
What filler wire should I use?
Thank you
Bob
ordered wire this morning
the only place to get it local is the welding supply store about 45 minutes away and they are not open on weekends
Thank you
Bob
I found a place closer that may have filler wire. But they are not open on Sunday.
Today if I get a metal art project I am working on done in time and the Ol'Lady does not have anything on her list for me to do, I plan to fire up the tig and just do some practice starts without the filler.
I had to do a brake job yesterday on my HHR and then start the art project piece I am dong for a friend, then Beer and Boxing so had no time for the trike or welder.
On the square exhaust I had to go through a number of test pieces before I finally got the shape/size i needed for the bolts will have room and still not restrict the exhaust
Next is to modify the actual exhaust pipes I made
I was thinking though.
Before I tack them to the exhaust flange I need to recheck the pinion angle. It should be good but its been a while since i checked that. If I have to adjust the engine/transmission angle any that will throw off my header angle
Thank you
Bob
OK before you say it know they look like crap.
But I will learn and they will get better
Thank you
Bob
some look not too bad...the end divot, needs to go...the tig videos should tell how to deal with that.
I don't have any filler wire yet. So I'm just doing it without filler.
I have a lot of practice to do.
I was running on 120V at 80 amps for then thin metal and 100 for the thick
I was using Blue Tungsten
I got caught with a the Ol'Ladys end table and she noticed I melted the epoxy cover on it.
Thank you
Bob
Stacebg is right....so many videos are of just making beautiful flat welds.....get used to moving the torch for tacks positioning angles for lapwelds..and favoring the heat on heavy sections when welding thick to thin.
