Likes Likes:  700
Thanks Thanks:  56
Page 21 of 33 FirstFirst ... 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 ... LastLast
Results 401 to 420 of 651
Thread: 88 blazer trike
  1. #401
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    Not done yet though. I still have to finish the wrap around and some dress up,
    Next weekend I hope to have the top to my fork mounts done.
    Also the top and bottom of my triple tree sill has extra steel on it. I don't want to cut that off until I am 100% sure I don't need it
    I bolted the top plate on my welding a 5/8" nut into a 1" then welding the 1" nut into the top of the fork legs.
    Thank you
    Bob
  2. #402
    Sep 2014
    Moneta VA
    Not a lot of time this weekend but I am going to try to get some done.
    I want to connect the 2 "wrap around" halves and put some shape to it as I do it.
    Want to level out the back part as I bring it together
    Im still thinking on how I want to top shock mounts
    Im hoping to get time Sunday
    The work on this is going slower than I want but I just do not have that much time now a days.
    Thank you
    Bob
  3. #403
    Sep 2014
    Moneta VA
    so I got as much of my other chores done as I could Saturday so I could work n the trike Sunday.
    Power went out Saturday night and did not come back on until Sunday night.
    SO did not get anything done to the trike.
    I do have to work next Sunday but I do have Saturday off. Hope to have time to work on it then.
    Thank you
    Bob
  4. #404
    Sep 2014
    Moneta VA
    did some work on the trike today.
    Made the shock mount tops.
    also started the "wrap around"
    How much space do I need to leave between the back of the wheel and the wrap around
    Thank you
    Bob
  5. #405
    450+ Posts
    Mar 2018
    Fernley
    Never built a wrap around, but have researched a bit and all that I have seen seem to be a inch or two.
    One thing is suspension travel, one wants to make sure that there is enough clearance for the rear of the tire to travel fully with out binding up.
    Other than that, all that I seen was it being more what the rider likes and how it looks to them.
    OH, okay one other thing that you have to remember, the travel of the steering side to side.
    Remember as you turn the wheel the rear is moving the opposite direction.
    For me with how my trike frame is the rear wrap around on the front end would wipe out my feet. All is just tight on my trike, but it is also why I am rebuilding my front end, partly to move the front end out from under the trike body and away from my feet some more.
    Looking good, it is coming along nicely.
    Also some use the wrap around for a fender bracket or attaching area for the fender. So that would be the closer wrap around and only about 1/2" on some front ends, this fender mounting distance also has to consider suspension travel of the tire so they do not hit one another.
  6. #406
    Sep 2014
    Moneta VA
    Im at work today just waiting on someone for I can finish up and go home. Just killing time right now.
    I was thinking about 2" Then if I do mount my fender to it I will just user a spacer if needed. Or just have a lot of clearance on my fender. I actually do not know how I will do the fender part yet. I have some crazy ideas but not to that point yet.
    Now I need to think about the steering. I want link steering. 2 shafts connected to the top plate going back to another plate and handle bars.
    Need to do some research on that
    Yesterday my son and I (about 400lbs together) both got on the trike, one of us one each side and bounced up and down like crazy. Everything held up good. No issues.
    Thank you
    Bob
  7. #407
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    I have the fender (750 honda) fitted inside the wraparound now....bolted directly, but have a harley style fiberglass fender that will someday find it's way on there.
    My wraparound is not tubular and therefore contributes less rigidity than desired.
    I have made a mudflap of stock car plastic....1/8" sheet...this bolts on with the fender lower mount.
    when I hit a fairly large pump, the mudflap will scrape on the road, makes a noise like scraping metal.
    You may want to give some consideration to mudflap design and fender mounting when you are finishing the "wrap".......my .02
    trike is looking good, you are making good headway!
  8. #408
    Sep 2014
    Moneta VA
    so next is my steering rods, rods connected at the forks going back a few feet to another neck and plate where the handle bars are at
    I call it a push pull type steering
    I plan to use heim joints with rods connected to them
    What will give me the best steering straight, smaller at the front or smaller at the rear?
    If I go with straight am I correct that wider is better?
    if anyone has any pics of Trikes setup like this I would love top see them
    Thank you
    Bob
  9. #409
    Jun 2016
    milnor n.d. usa
    not sure...but i think there was a thread here on trike talk about these linkage choices, maybe the non parallel linkages would bind up at some point in their travel? thought the thread discussed this?
    Hopefully some one will remember.
  10. #410
    Sep 2014
    Moneta VA
    Quote Originally Posted by LarryA View Post
    I found it
    https://www.triketalk.com/forum/thre...-Pull-Steering
    Thank you
    Bob
  11. #411
    600+ Posts TomyJ's Avatar
    May 2016
    Hemet, Ca. USA
    Default Wrap around
    Something like this... Name:  MC front suspension leading link.jpg
Size:  77.1 KB Or no! The more the support the smoother the ride...
    JakeJacobsen@Pinterest.com
  12. #412
    Sep 2014
    Moneta VA
    Having a hard time posting
    will try again
    had 4 days off but had to repair fences 2 of the days
    Yesterday I did have some time so I worked on the wrap around
    Next I plan to work on some type of guard around the neck seals
    Thank you
    Bob
  13. #413
    Sep 2014
    Moneta VA
    Once this guy is back I will be ordering another frame neck
    This one will go at the handle bar end
    https://www.ebay.com/itm/Motorcycle-...-/152785382581
    Thank you
    Bob
  14. #414
    Jun 2016
    milnor n.d. usa
    the wraparound looks good, should be plenty rigid.
    the 7 in tube will get your handle bars up to a good height.
    I like the parallel steering rod idea, then handle bars do not need to be pulled back so far. Some bars are so pulled back it would be like tiller steering!
  15. #415
    Sep 2014
    Moneta VA
    The guy i bought the neck from last time is not answering my emails.
    His ebay listing says he is out
    If he does not answer by tomorrow I will have to order something else.
    Was looking at this
    They sell the bearing to go with it also
    Don't really need the stop, If its in my way I will cut it off
    https://twistedchoppers.com/shop/fra...SABEgIBsfD_BwE
    Thank you
    Bob
  16. #416
    Sep 2014
    Moneta VA
    ordered the neck and bearing yesterday
    Thank you
    Bob
  17. #417
    Sep 2014
    Moneta VA
    I have 4 days off coming up.
    I hope to get some work done on the Trike then
    I have the 2nd neck and some metal to work with
    I just need to keep out of site of the Ol'Lady for she doe snot put me to work.
    Thank you
    Bob
  18. #418
    May 2016
    Hemet, Ca. USA
    Quote Originally Posted by Fowler View Post
    I think you mean "Honey Dooo's"
  19. #419
    Sep 2014
    Moneta VA
    I am headed to the shop to start working on the trike in a few minutes.
    On the trike below the front and back necks and plates look to be about the same angle.
    I was planning to make the back plate flat(not at an angle) and have bent risers on the front plate to make that connection not at an angle
    Thank you
    Bob
  20. #420
    Jun 2016
    milnor n.d. usa
    agree on the plates being parallel with the link rods......or at least the last few inches of the plates twisted to be parallel.
  1. Happy Birthday Trail Blazer
    By Papa Zook in forum General Discussion
    Last Post: 12-07-2016, 02:39 PM
