Ironhorse542Ironhorse54California Sidecar T...Helmet release button
Kneesinbreeze9rhino 2Harley Freewheeler /...Hiway pegs without installing crash...
Kneesinbreeze9Papa ZookHarley Freewheeler /...Hiway pegs without installing crash...
Davep6DavepHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
Ironhorse542Papa ZookCalifornia Sidecar T...Helmet release button
Kneesinbreeze9JerseyGirlRiderHarley Freewheeler /...Hiway pegs without installing crash...
DK Custom Products362SmittysTrikeHarley Tri GlideWhat did you do to Your Tri-Glide T...
Vin5Rogue1Harley Tri GlideCold Engine Revs High When Starting
diferg13hardwickbvNew Member Introduct...Hello from Southeast Georgia U.S.A
diferg13woodyNew Member Introduct...Hello from Southeast Georgia U.S.A
ZZMACH15Jack KlarichHarley Tri GlideElectric Fans on 2014 Tri Glide
Kneesinbreeze9Jack KlarichHarley Freewheeler /...Hiway pegs without installing crash...
TomyJ7Jack KlarichHome Built TrikesShenanigans
Vin5Jack KlarichHarley Tri GlideCold Engine Revs High When Starting
dthorn8Rogue1Harley Tri Glide2024 Tri Glide front axle nut torqu...
MDO101DK Custom ProductsHarley Freewheeler /...What Did You Do To Your Freewheeler...
diferg3Motorcycle MikeChampion TrikeChampion irs banging noise on bumps
Kneesinbreeze9My TurnHarley Freewheeler /...Hiway pegs without installing crash...
MDO101LD-OrdieHarley Freewheeler /...What Did You Do To Your Freewheeler...
diferg3difergChampion TrikeChampion irs banging noise on bumps
Rogue15Rogue1Harley Tri GlideOil pressure gauge.
Vin5Dan SCHarley Tri GlideCold Engine Revs High When Starting
Rogue15Dan SCHarley Tri GlideOil pressure gauge.
HDUSA113ol' schoolNew Member Introduct...New to Trike Talk
diferg13ol' schoolNew Member Introduct...Hello from Southeast Georgia U.S.A
scuzzi4scuzziHarley Tri GlideTri Glide extended reach seat
Vin5rhino 2Harley Tri GlideCold Engine Revs High When Starting
diferg3Marc HChampion TrikeChampion irs banging noise on bumps
Vin5VinHarley Tri GlideCold Engine Revs High When Starting
Frisco5Marc HCalifornia Sidecar T...Side pod door open signal
diferg13Uncle FesterNew Member Introduct...Hello from Southeast Georgia U.S.A
JohnnyVDA13Uncle FesterNew Member Introduct...Hello I am from Belgium
jef_nik20002jef_nik2000Lehman TrikeMonarch 2 center cap removal proced...
jef_nik20002Papa ZookLehman TrikeMonarch 2 center cap removal proced...
Tritek4stancotreauLehman TrikeAvoid buying a Lehman?
Rogue15Jack KlarichHarley Tri GlideOil pressure gauge.
Tritek4Papa ZookLehman TrikeAvoid buying a Lehman?
gfaltersack8DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
Kneesinbreeze9Noodles107Harley Freewheeler /...Hiway pegs without installing crash...
Rogue15Old Road DogHarley Tri GlideOil pressure gauge.
Tritek4TritekLehman TrikeAvoid buying a Lehman?
Burnerboy11rhino 2Can Am Spyder Trike...How many of you ride a Can Am spyde...
JohnnyVDA13Phu CatNew Member Introduct...Hello I am from Belgium
ZZMACH114BrokenBackJackHarley Tri GlideNew Member Hello from NH
diferg13BrokenBackJackNew Member Introduct...Hello from Southeast Georgia U.S.A
JohnnyVDA13BrokenBackJackNew Member Introduct...Hello I am from Belgium
JohnnyVDA13Papa ZookNew Member Introduct...Hello I am from Belgium
Frisco5FriscoCalifornia Sidecar T...Side pod door open signal
JohnnyVDA13Jack KlarichNew Member Introduct...Hello I am from Belgium
diferg13Jack KlarichNew Member Introduct...Hello from Southeast Georgia U.S.A
ZZMACH114SullyHarley Tri GlideNew Member Hello from NH
diferg13SullyNew Member Introduct...Hello from Southeast Georgia U.S.A
Kneesinbreeze9pigfoot63Harley Freewheeler /...Hiway pegs without installing crash...
AriNV14KneesinbreezeNew Member Introduct...New to trike
Burnerboy11KneesinbreezeCan Am Spyder Trike...How many of you ride a Can Am spyde...
TXFIRE766BurnerboyHonda TrikesNew to Trikes and needing a convers...
smokey_mountain2BurnerboyAccessoriesJ&S Moto conversion to Trike Li...
Frisco5BurnerboyCalifornia Sidecar T...Side pod door open signal
Frisco5ol' schoolCalifornia Sidecar T...Side pod door open signal
ZZMACH114trike ladyHarley Tri GlideNew Member Hello from NH
JohnnyVDA13trike ladyNew Member Introduct...Hello I am from Belgium
diferg13trike ladyNew Member Introduct...Hello from Southeast Georgia U.S.A
diferg13rhino 2New Member Introduct...Hello from Southeast Georgia U.S.A
diferg13GorillaNew Member Introduct...Hello from Southeast Georgia U.S.A
ZZMACH114Marc HHarley Tri GlideNew Member Hello from NH
diferg13Marc HNew Member Introduct...Hello from Southeast Georgia U.S.A
diferg13ZammyNew Member Introduct...Hello from Southeast Georgia U.S.A
Bloke10Marc HNew Member Introduct...Hello from Uttoxeter UK
JohnnyVDA13Marc HNew Member Introduct...Hello I am from Belgium
Kneesinbreeze9ZammyHarley Freewheeler /...Hiway pegs without installing crash...
diferg13difergNew Member Introduct...Hello from Southeast Georgia U.S.A
Phill Griggs2ZammyTrike TravelPIE-PIE & PIE
Bloke10ZammyNew Member Introduct...Hello from Uttoxeter UK
JohnnyVDA13ZammyNew Member Introduct...Hello I am from Belgium
Frisco5rhino 2California Sidecar T...Side pod door open signal
Rogue15rhino 2Harley Tri GlideOil pressure gauge.
JohnnyVDA13hardwickbvNew Member Introduct...Hello I am from Belgium
ZZMACH114hardwickbvHarley Tri GlideNew Member Hello from NH
Kneesinbreeze9KneesinbreezeHarley Freewheeler /...Hiway pegs without installing crash...
ctdair1ctdairHarley Tri GlideFixed Switch
Davep13GorillaNew Member Introduct...Hello from the mountains
ZZMACH114GorillaHarley Tri GlideNew Member Hello from NH
HDUSA113GorillaNew Member Introduct...New to Trike Talk
JohnnyVDA13GorillaNew Member Introduct...Hello I am from Belgium
Bloke10GorillaNew Member Introduct...Hello from Uttoxeter UK
Sunman7GoldWingrGregHonda TrikesF1 Warning Light
ZZMACH11ZZMACH1Harley Tri GlideRinehart VS Vance & Hines for M...
Bloke10rhino 2New Member Introduct...Hello from Uttoxeter UK
JohnnyVDA13rhino 2New Member Introduct...Hello I am from Belgium
JohnnyVDA13ol' schoolNew Member Introduct...Hello I am from Belgium
JohnnyVDA13JohnnyVDANew Member Introduct...Hello I am from Belgium
Bloke10Jack KlarichNew Member Introduct...Hello from Uttoxeter UK
Bloke10SullyNew Member Introduct...Hello from Uttoxeter UK
Bloke10ol' schoolNew Member Introduct...Hello from Uttoxeter UK
Bloke10hardwickbvNew Member Introduct...Hello from Uttoxeter UK
Bloke10trike ladyNew Member Introduct...Hello from Uttoxeter UK
Burnerboy11BurnerboyCan Am Spyder Trike...How many of you ride a Can Am spyde...
Phill Griggs2Phill GriggsTrike TravelPIE-PIE & PIE
ZZMACH13Longbeard71Harley Tri GlideLooking for Dynajet Power Vision mo...
Bloke10BlokeNew Member Introduct...Hello from Uttoxeter UK
Papa Zook2Jack KlarichHarley Tri Glide2024 Harley Trikes Lineup - Laidlaw...
ZZMACH12Jack KlarichHarley Tri GlideElectric Fans on 2014 Tri Glide
ZZMACH13Jack KlarichHarley Tri GlideLooking for Dynajet Power Vision mo...
Davep6Jack KlarichHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
Smitty9013Marc HSidecar ForumSmall crack down the rabbit hole
HDUSA113Marc HNew Member Introduct...New to Trike Talk
HDUSA113ZammyNew Member Introduct...New to Trike Talk
Oldman-TriGlide10ZammyHarley Tri GlideEnclosed Trailer Size
Smitty9013ZammySidecar ForumSmall crack down the rabbit hole
HDUSA113Uncle FesterNew Member Introduct...New to Trike Talk
ZZMACH114Uncle FesterHarley Tri GlideNew Member Hello from NH
ZZMACH114stancotreauHarley Tri GlideNew Member Hello from NH
Davep6rhino 2Harley Tri GlideTRI GLIDE AIR FILTER QUESTION
Smitty9013Smitty901Sidecar ForumSmall crack down the rabbit hole
ZZMACH114TrampasHarley Tri GlideNew Member Hello from NH
Likes Likes:  5
Results 1 to 7 of 7
Thread: Rewaco VW Transmission oil question
    20+ Posts
    Apr 2016
    UK
    Default Rewaco VW Transmission oil question
    Hi
    I have a VW 1800i Rewaco trike (2006), I was very lucky to find this genuine 2k mile trike and over the winter I have been going through it from top to bottom as it had been stood for a number of years. Anyway I got to changing the transmission oil and the exhaust collector box and truck pipes make it impossible to get to the gearbox oil drain screw without removing a ton of stuff which I would like to avoid.
    I have used a vacuum pump to take out as much hypoid oil as possible, jacked up the rear of the trike as high as possible to move the oil closer to the fill hole which I was using to pump out the old oil. I have managed to get 2ltr of the 2.5ltrs of oil out of the gearbox, if I was to fill with new oil will this be OK? Just can't get all the old oil out..... Old oil looks in good shape only done 2k miles but has been in for 10 years.
    thanks and sorry for the European measurements but not sure of the US Equivalent.
    thank you
    Meme Master
    Jan 2014
    Farmington, NH USA
    Of course, as you are likely aware, the only real way to remove old oil & potential contaminates is to fully drain the gearcase.
    In the scenario you detail, were you able to inspect the condition closely for particulates/contaminates?
    I assume you didn't send a sample for laboratory analysis?
    If your old oil looked fairly clean with nothing floating around in it or contaminated with water, you should be able to top off with fresh oil & ride. VW transaxles are fairly forgiving, especially if the old oil only had 2K on it & was not found with metal or other foreign matter in it...
    "Tin Man" Doug D.'s Avatar
    May 2012
    Vienna, MO USA
    Ditto, took the words right outta my mouth. Congrats on the find, too! How 'bout some pics?
    PEACE and ride safe!
    20+ Posts
    Apr 2016
    UK
    Quote Originally Posted by Doug D. View Post
    Thanks guys, thought I may be OK, going to try and get a bit more out before I top up, old oil in good condition so if I can get 85% new oil in I will be fairly happy. No pics worth posting yet but as soon as I get it back together again I'll post some. Thank you
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    I wonder if rewaco has a spec on the oil.
    I would think that if they were going to make it impossible to change that they would have put a synthetic oil in it.
    I dont like mixing types of oil.
    Ok with me to mix brands of the same spec/type oil.
    Synthetic is good stuff, but everything needs to be in real good shape in there. Putting synthetic in a worn gear is just gonna make it sound worse. Film strength is high but film thickness is small. Just aggravates an already worn condition.
    Got an excellent box? Go synthetic and it will stay that way near forever.
    GL 5 dino is a better oil than GL 4....
    BUT.
    GL 5 is not required to pass the yellow metal corrosive test at all.
    Most GL 5 IF tested would pass. But untested it is an unknown. If you put it in your VW trans you will probably be OK and maybe not. No way to know without the grade test.
    GL 4 is a lower grade of oil, not hypoid. But it does pass the yellow metal test as it is required for it to be GL 4 spec.
    VW specs GL 4. The ring is not hypoid and the trans has yellow metal parts.
    I use a valvoline dino gear oil that has the combo rating GL 5 and GL 4. If the labeling is true and they are not falsifying documents that would mean that it passes all the test of 4 and 5.
    Meme Master
    Jan 2014
    Farmington, NH USA
    Synthetic vs dino, syn wins about every time in terms of total internal drivetrain protection.
    Won't help if the trans-axle/gearcase is tired, or has multi miles without much else done to it maint wise.
    This OP's inquiry seems to only have 2K of mileage on it since "new"?
    In my opinion also, it would be worth the inquiry to Rewaco to see what is installed or recommended for use in their vehicles for lubrication.
    Best to use what is recommended or as close to what is recommended, for everyday use & peace of mind.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Yep.
    Was what I was thinking also.
    With an upscale build like a Rewaco you would think they would start with a fully reconditioned trans complete with synthetic oil for longevity of box and a long time before an oil change.
    Dont mix dino with syn.
    Find out what they had in it. I bet it was not the old antique GL 4 and a half wore out box.
  1. REWACO FX4 2006 front wheel question
    By Retepnikrap in forum General Discussion
    Last Post: 06-18-2016, 03:25 PM
  2. Question for Rewaco RF1 owners
    By pisoiu in forum Rewaco
    Last Post: 06-12-2016, 03:08 PM
  3. Replies: 20
    Last Post: 03-29-2011, 02:36 PM
  4. A VW transmission question
    By nightwalker in forum VW Powered Trikes
    Last Post: 09-26-2008, 09:44 PM
