Results 1 to 13 of 13
Thread: Car tire on Burgman 650
    Default Car tire on Burgman 650
    I just put a car tire on my burgman trike, had to grind off the bead and take a bit off the rim to get it to go on. Tire is a Bridgstone 165/65 14. Wayne
    www.burgmantrikes.com
    20+ Posts
    May 2009
    Central Florida
    Default Re: Car tire on Burgman 650
    Let us know how that works..
    Were you doing thinking it would be an improvement?
    I just cannot believe grinding part of a tire off is a good thing.
    I ground part of the bead off the rim so it would not be so hard to put the tire on the rim. Makes a softer ride, and when I took the tire off it was realy hard to break down, so grinding it down did not hurt it. Lots of people have put them on the burgman 650 and like them great, but did not grind the rim down. It takes about 100 lb pressure to get it on if you dont grind it down, about 40 to get mine on. If you go to BurgmanUSA Forum and Website and look for darkside you will find lots of info on the tire. I did not grind any of the tire. The car tire is about 1/4 in smaller inside thats why its hard to mount on rim. Wayne
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    This is the rear tire?
    20+ Posts
    May 2009
    Central Florida
    OK I misunderstood,,I thought you were actually grinding off some of the tire.
    So are you pleased with the change?
    90+ Posts
    Frisco, Texas
    I'l bet he is. Stallions come with automobile tires all the way around.
    They also last a lot longer than motorcycle tires due to the wider surface on the ground.
    Remember, since we don't lean like a two wheeler that side tread is wasted.
    Yes it is the rear tire, very pleased with it, lasts longer , cheaper and smooth. Wayne
    400+ Posts
    Feb 2008
    Central Texas
    Quote Originally Posted by Seatec View Post
    Please help me understand. Your AN650 has been triked [1f/2r]? It now has a total of three wheels? You are using a Bridgstone passenger tire on the front or on the two rear wheels? Thanks.
    3 wheels on back, Potanza car tire on center back wheel 165/65 r 14, out side 2 back wheels has a Danson kit, tires are 175/65 R 14. Wayne
    My new trinity trike will only have 2 back wheels, thats where you may have been mixed up. Wayne
    700+ Posts
    Jan 2012
    Cayce SC
    I know a guy in Columbia SC who rode a 650 Burg all the way to Alaska and back and he had a car tire on the back..
    10000+ Posts skuuter's Avatar
    Apr 2010
    Estill Springs, Tn, USA
    I saw this on a Burgman Trike Conversion for the first time. It was parked at Sloan's Motorcycles in Murfreesboro, Tennessee last Saturday. Come to find out, I know the Owner from years ago. He really likes it and I may get to ride it myself in the future.....I'll be sure to post here if I do.....
    50+ Posts DanB's Avatar
    Jan 2013
    Troup, Tx
    I run a Dunlop Wintersport Runflat car tire on the rear of my 95 Aspencade. Have since added a Tow Pac Insta Trike. After 8000 miles I still see no tire wear. Hope to get 25-30k on it.
  1. Burgman 400
    By countryartist in forum 2 Wheelers
    Last Post: 05-22-2012, 12:29 AM
