Likes Likes:  6
Results 1 to 14 of 14
Thread: Trouble finding neutral
    200+ Posts
    Nov 2016
    groesbeck texas usa
    Default Trouble finding neutral
    ​When I go from first to N, it just flies past it on the dash. Does anyone else have this problem? Now with the engine off no problem
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Quote Originally Posted by lightnin View Post
    It sounds like a clutch adjustment issue....
    Jim Murphy
    Iron Butt Rider 2001
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Common problem, I just lightly tap on the heal shifter, And it goes in...[Most of the time..]
    2019 Tri-Glide.......
    gerald martin
    Guest
    Default neutral
    make sure you have the exact amount of oil in your primary and your clutch is adjusted. If you have the hydraulic non adjustable clutch the primary needs more oil than the adjustable clutch
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    Changing to real gear oil in the transmission solved my problems. I use Bel-Ray 85W-140. There are many other choices for Harley transmission gear oil. I also use a heel tap from first to get to neutral.
    Having a 2014 I use 40 ounces of H-D Formula+ for the primary/clutch.
    Bob
  6. DKCustoms postbit
  7. #6
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Lots of good advice.
    Could be a combination of many things.
    Run some good gear oil in tranny, like redline shockproof
    Have the clutch adjusted correctly, and the primary not overfilled, which is commonly done at dealerships. (the clutch dragging from improper adjustment and/or overfilled primary is the most common reason for difficulty in finding neutral)
    Use heim joints on shift linkage for more positive input from the foot
    When in first, it is usually easier to tap the heel shifter to get to neutral, than to lift the toe shifter.
    www.DKCustom.com
  8. #7
    60+ Posts 30glock's Avatar
    Jul 2016
    Somewhere in usa
    All due respect to all that gave an opinion here, but there Is not a product available anywhere that will claim It can help you find neutral, oil companies would love to make that claim but they can't, JMHO.
    My advise is to stop trying to find neutral with your toe, It's a simple tap with your heal and knowing how much pressure to apply, try this before throwing money at a non existing problem.
  9. #8
    100+ Posts Trikesyke's Avatar
    Oct 2016
    New York
    Also, a quick throttle blip while attempting to hit N helps.
    2015 Tri Glide Ultra Classic - White Hot Pearl / Blue Hot Pearl
  10. #9
    200+ Posts
    Nov 2016
    groesbeck texas usa
    I'll double check my clutch adjustment.Thanks for the in put. I'am old school and took the heel shifter off the first thing. I'll check the clutch adjustment first.
  11. #10
    250+ Posts
    56Elwood's Avatar
    Jul 2010
    Groveland Massachusetts USA
    Plus 1 on the Redline Shockproof. Used that in my CVO Convertible, it worked wonders!
  12. #11
    200+ Posts
    Nov 2016
    groesbeck texas usa
    Default learning curve
    I have never ridden with a heel shifter and I'am 68. So after reading your replies I go put the heel shifter back on and found netural first try now just have to remember "light tap" Thanks for the advice
  13. #12
    300+ Posts
    Dec 2014
    florissant
    how new is the bike ? if it's new it will get better as time goes on.
    hardheaded
  14. #13
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by headheaded View Post
    The bike doesn't get better at it.... The guy shifting it gets better at it......
  15. #14
    300+ Posts
    Dec 2014
    florissant
    i meant as the bike became broken in it will loosen up some . every new bike i've had was tight when new.
    hardheaded
  1. Finding neutral
    By Lazycats in forum Harley Freewheeler / Road Glide 3
    Last Post: 10-23-2016, 10:29 PM
  2. trouble getting neutral on cold '14 TriGlide
    By MB1953 in forum Harley Tri Glide
    Last Post: 09-19-2014, 03:13 PM
  3. Finding Neutral
    By Trapper54 in forum Harley Trike Conversions
    Last Post: 05-13-2014, 11:30 AM
  4. trouble finding correct belt
    By MAW in forum Harley Trike Conversions
    Last Post: 04-10-2013, 07:44 AM
