Likes Likes:  5
Page 2 of 2 FirstFirst 1 2
Results 21 to 24 of 24
Thread: ATV rear differential?
  1. #21
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by Bykas View Post
    I have no wobbles, steering is excellent now. Without dampers when I'd let go of the bars bike would pull slightly one way or the other depending on the road. With the dampers fine tuned steering stays perfectly straight which greatly enhances the cornering ability not to mention confidence. On my Fazer they are mounted on each side of forks, my gsxr600 has them on upper and lower forks as seen in pics. Got them on Ebay, work excellent. Had to make custom mounts for them on the Fazer.
    so that means u had wobbles before u put on the damper??
  2. #22
    750+ Posts
    Jan 2010
    east windsor ct
    [QUOTE Without dampers when I'd let go of the bars bike would pull slightly one way or the other depending on the road. With the dampers fine tuned steering stays perfectly straight [/QUOTE]
    what you are saying is it acts like a spring to stop that pull .. correct???
  3. #23
    20+ Posts
    Dec 2018
    Oregon City
    Had slight wobbles till I lowered the forks for more negative trail. Its all trial and error till you get it to your personal liking.. Dampers allow you to dial in steering from side to side.
  4. #24
    20+ Posts
    Dec 2018
    Oregon City
    what you are saying is it acts like a spring to stop that pull .. correct???[/QUOTE]It just stiffens up the steering so it tracks straight.
  1. Differential leak
    By OLD DAWG in forum Roadsmith Trikes
    Owners Forum
    Last Post: 05-31-2016, 07:59 PM
  2. rear differential service
    By johndeeredr in forum Harley Tri Glide
    Last Post: 05-27-2016, 11:05 PM
  3. Differential oil
    By katonka in forum Honda Trikes
    Last Post: 08-06-2014, 08:46 AM
  4. Differential offset
    By Jakeboy in forum General Discussion
    Last Post: 01-16-2012, 12:44 AM
  5. Rear Differential
    By Davidf66 in forum General Discussion
    Last Post: 02-04-2010, 03:24 PM
