Likes Likes:  9
Results 1 to 17 of 17
Thread: How well do your rear brakes work?
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Default How well do your rear brakes work?
    About a week ago a fellow Tri-Glide Rider was talking to me about how his rear brakes did not work very well. Specifically, no matter how hard he pushed on the brake pedal they did very little to slow him down.
    He did not believe his rotors or pads were glazed or greasy. It just seemed that he pushed Far harder on the brake pedal than he ever would on a two wheeled bike, and it resulted in very little stopping power.
    I have read of others that have had similar complaints.
    My experience has been that the rears brakes, while needing substantially more pressure on the pedal to work, have always worked very well.
    I suggested that he go 20 miles per hour (on a deserted road) and push on the pedal as hard as he could. This should lock up the back tires. If it didn't, then something was definitely different than what I have experienced on my own Tri-Glides ('11 & '14).
    The day after I spoke with him I was riding and decided to do a little test.
    (I should have taken pictures, and I may do it again and get photo's)
    20 mph, let off on throttle and pushed brake pedal hard....rear tires locked up.
    Sped up to 30 mph, let off on throttle and pushed brake pedal hard....rear tires locked up.
    Sped up to 40 mph, let off on throttle and pushed brake pedal hard....rear tires locked up.
    Sped up to 50 mph, let off on throttle and pushed brake pedal hard....rear tires locked up.
    I thought about doing it at 60 mph, but was already smelling all the rubber I had already taken off my tires.
    Conditions-
    Dry asphalt
    Straight level road
    I did not notice any brake fade, even though I was doing this one right after another. Probably because I was going from no brake to lock up. That would not generate as much heat as the brakes being on lightly for an extended time.
    There was no fishtailing, Trike stayed straight while tires locked up.
    Coming from two wheels, I primarily use my front brake for slowing/stopping. I only add the rear brake if I need to slow down faster than usual.
    Prior to my little test I was happy with my rear brakes on the TG, now I am even happier with them, knowing that I can brake as hard as I want with the rear brakes, even at speed, and they will slow me down as fast as the tire traction will allow.
    www.DKCustom.com
    150+ Posts 5x40's Avatar
    Oct 2013
    Land Between the Lakes, Tn
    when I took the trike riders course for reduced insurance purposes last yr; I already had 4 yrs on it, anyways one of the new riders had the same concern. I went to far end of lot and when I got down to the other end I locked them down/up. nothing but black marks behind me. made a believer out of him and I think it also made him a little more comfortable.
    50+ Posts tnbillybob's Avatar
    Dec 2016
    Hornsby, Tn, USA
    Stops like yours Kevin. I had a slight adjustment to make coming off a 14 Limited 2 wheeler with abs. It's all good now.
    150+ Posts prariepilot's Avatar
    Apr 2016
    North Ridgeville OH, USA
    I've found that, since the change-over to EBC Pads on my '13, I can also lock the brakes at most speeds. EBCs seem to perform much better than the stock H-D pads ever did.
    Still wish I could get my hands on a set of rear Lyndall pads!
    Thanks, Kevin.
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    The rear brakes on my buddies 09 are not near as good as the ones that were on my 16 or my 17,even after turning the rotors and installing new pads.
    Apr 2016
    Out of the Service Manual:
    Disc Brake Thickness
    Inspect Brake Disc surface condition. Replace disc if pitted, grooved or scored.
    Inspect Brake Disc for excessive wear. Replace disc if thickness is 0.220 inches (5.59mm) or less.
    If the rotors are turned too thin, it will diminish the braking capability. Won't stop near as good. Get new rotors. and GOOD pads!
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    I am sure that many owners of older TGs with low mileage are not aware that their were rotor issues which were finally addressed by this service bulletin.
    Name:  rotor bulletin 09-13.jpg
    40+ Posts
    Mar 2016
    Tehachapi, Ca, USA
    I haven't tried the test procedure you did but I can tell you the rear brakes on our 2012 are pretty poor. The pedal is firm but the brakes feel numb and I have to really stand on the pedal to get any real braking action. I inspected the brakes and the rotors are pretty scored. I have on hand new rotors and EBC pads - just waiting for a surge of ambition to get out and change them. We bought this trike used with 12,000 miles on it so the brakes are the way it came and I have no idea how the previous owner drove it. I guess I better get busy and change the brakes.
    Nov 2015
    kenyon
    I have the same problem with my 2010 trike very poor stopping power. I installed new ebc pads replaced dot 4 fluid. Didn't see any changes in stopping power. Open to any ideas as what to do in making brakes work better.
  11. #10
    Quote Originally Posted by Dug,s garage View Post
    Did the same...Sure if you prepare for it... You can stand on the rear brakes and lock the tires... That said in a normal driving situation and the car in front suddenly stops short for no apparent reason, They work as good as the brakes on a 49 Plymouth.
    I learned that more so than with any other Trike or Bike.. I always leave more space between me and a vehicle in front...And always/always cover the front brake lever with two fingers when in any kind of traffic ...
  12. #11
    300+ Posts 67wizard's Avatar
    Aug 2015
    Nv.
    I feel better riding in town with my fingers over the brake lever also.
    Never know what the nut in front of you is going to do.
    CMA member, VietNam 66-67
    25th Inf. Cu Chi
    2016 Tri Glide.
    :) Its' me again.
  13. #12
    1500+ Posts
    Apr 2016
    Dayton Ohio
    Quote Originally Posted by prariepilot View Post
    Rotors were within limits and we used HD pads.
  14. #13
    1500+ Posts
    Apr 2016
    Dayton Ohio
    While i had my buddies 09 on the lift we talked about doing the rotor conversion by machining a set of rear ford focus rotors but he wanted to try turning them first.I had my concerns about running a cast iron rotor,but after looking at the Drag catalog they offer cast iron rear rotors that list for $ 119 rather than $ 175 for HD's. so as soon as i can get some time I will be turning a set of cast iron rotors for him.
  15. #14
    Quote Originally Posted by HDB0B View Post
    That was for Noise reduction....Not for performance ..[Stoping]
  16. #15
    450+ Posts MB1953's Avatar
    May 2014
    Peru, IN USA
    I had no issues with my '14... stopped quicker and straighter than any 2 wheeler I ever was on. Recently I found out about the stopping power of my '17... I was tooling around, daydreaming (not a wise move) and realized that I was about to miss the turnoff I wanted. I hit the brake pedal and almost instantly was greeted with a 2 wheel tire squeal. I thought someone was about to rearend me until I glanced in the mirrors and realized there was nobody behind me. Scared the crap out of me! Also made me pay more attention!
    2017 TriGlide Vivid Black - DK Outlaw AC, Fullsac performance baffles, PowerVision from DK, Love Jugs Mighty Mites from Papa Zook, HD Black Reach Bars, all kinds of BLACK stuff... Hi, my name is Mark and I used to be a chromeaholic!
    was - 2014 TriGlide Vivid Black - DK Custom Lift, 2" tank lift, DK Dual Cool, DK Discrete breather, Wards Parts Werks FCS, HD Reach Bars, all kinds of shiny stuff!
  17. DKCustoms postbit
  18. #16
    1500+ Posts
    Apr 2016
    Dayton Ohio
    The braking power of the 17 trikes are pretty amazing.My 16 was as good as my 17.
  19. #17
    100+ Posts
    Oct 2013
    Ohio
    Default Brakes
    My 14 tri the left side rotor has some rust on it.the right side you can see it is working.Any ideas what is wrong?
  1. Rear brakes
    By 67wizard in forum Harley Tri Glide
    Last Post: 01-05-2017, 10:24 AM
  2. Rear Brakes
    By Dude in forum Honda Trikes
    Last Post: 07-03-2016, 08:49 PM
  3. Rear disc brakes, VERY HARD pedal, weak brakes????
    By TrikerDoone in forum VW Powered Trikes
    Last Post: 05-29-2016, 12:14 PM
  4. Rear Brakes
    By cact57s1 in forum Honda Trikes
    Last Post: 10-27-2014, 08:44 AM
  5. What rear tire will work best to drive my Voyager kit ?
    By krazybob in forum Outrigger Style Trikes
    Last Post: 02-23-2014, 02:44 PM
