14TG314TGHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3Jack KlarichHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
Results 1 to 6 of 6
Thread: cam chain noise
    50+ Posts
    Aurora Indiana USA
    Default cam chain noise
    Is it normal to hear the cam chain. I have an 08 1800 with 50000 on it. when at idle I can hear the cam chain. It doesn't seem excessive loud. I was just wondering if that is the norm
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Sorry, but on a GL1800, I've never heard cam-chain noise. I've read others who talk about it, but have never heard it myself. Can you take a video with your smartphone, email it to yourself, open it and verify that it has the sounds you are hoping others can hear, then post it on youtube and copy and past the link here ???
    To my knowledge, cam chain noise on a GL1800 does not exist, but I could be wrong.
    Does it sound like this ???
    JustWings.com
    May 2016
    In the video post above, I hear 4 noises. All 4 are normal; however, 1 should mostly go away if he center-spected his valve adjustment.
    50+ Posts
    Aurora Indiana USA
    That is not the sound I am hearing. And pulling in the clutch does not change the sound. As for the video, I am electronically challenged. I will see if I can get my grandson to help. After the bike gets up to normal temp. the noise gets quieter. But it is still there after the engine drops from fast idle to normal idle.
    JustWings.com
    May 2016
    Quote Originally Posted by David357 View Post
    Do any of those 4 individual sounds stop if the clutch lever is pulled in?
    I'm not hearing any clutch related noise in that video.
  1. Safety Chain
    By wehrme in forum Trailers / Campers
    Last Post: 07-29-2014, 06:48 AM
  2. Cam Chain Tension shoes
    By luzierg in forum Harley Trike Conversions
    Last Post: 05-11-2014, 04:55 PM
  3. primary chain adjustment
    By engprosinc in forum Harley Trike Conversions
    Last Post: 06-20-2013, 03:03 PM
  4. Chain adjuster on swingarm.
    By BIBS in forum General Discussion
    Last Post: 11-08-2010, 11:56 AM
