Results 1 to 17 of 17
Thread: ABS Plastic
    100+ Posts
    Mar 2010
    Wheeler,Texas
    Default ABS Plastic
    Can it be repaired?? Discovered a rather large crack in the trunk lid on the GW,and dont even wanna think about what a new trunk lid would set us back
    1250+ Posts katfish16's Avatar
    Feb 2008
    Gallion, Alabama
    Default Re: ABS Plastic
    Most cracks in the trunk lids come from improper closing, or from overlaoding the luggage rack.
    Can it be fixed???
    I would check with a shop or person who works on Corvetts, they would atleast have knowledge if it can be repaired...
    Might also look on E=bay to see if U can find one....
    Good luck
    Steve & Cathy
    Alabama
    U.S. Coast Guard (retired)
    30+ Posts Simdog's Avatar
    Jun 2010
    West Monroe, LA
    Quote Originally Posted by 2fromTX View Post
    I've heard of folks repairing it with some type of epoxy. However, many folks mistake it for fiberglass and try to do a fiberglass repair on it.
    You might try a place that repairs Jet Ski's. My neighbor here does and he can repair anything that's some type of Plastic.
    500+ Posts tis's Avatar
    Dec 2008
    West Falls, N.Y.
    You can have it plastic welded. Also if it's in a spot that is'nt too noticeable, I've drilled a micro size hole so the crack don't travel further.... start with the drill & a little pinstriping and see what happens from there, cause once you go the plastic weld route you''ll have to do some painting also....
    10000+ Posts skuuter's Avatar
    Apr 2010
    Estill Springs, Tn, USA
    Quote Originally Posted by tis View Post
    Yep, most really good Automotive Body Shops can do this now (...how They repair small cracks on ABS bumpers).....works pretty well in low stress places.....:wtg:
    Most automotive stores handle a product xalled "plastic weld" . The stuff is great--
    I put a susuki fender back together with it that shattered into many small pieces
    Remember--It is never the issue but rather how we react to the issue is the issue.
    http://www.buggy.com/
    07 VTX 1800 w/Champion Trike Conversion
    [SIGPIC][/SIGPIC]
    Feb 2008
    Gallion, Alabama
    I checked on E=bay and there are several listed. So see which one is better to fix or replace. Good luck and keep us informed on how it goes....
    Steve & Cathy
    Alabama
    Jun 2010
    Indianapolis, In.
    JB Weld
    FYI:
    Corvettes are fiberglass not ABS
    Soft bumpers are not ABS, most are polyurethane.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    Remember I welded my side cover back together . Only thing is that it does not get the abuse a trunk lid gets.
    TOI - North Carolina
    Jul 2009
    Mooresville NC
    I had someone fix my 1500 with plastic weld! It worked just great!
    the Suzuki front fender i did was in at least 25 pieces , probably more, my wife likes doing jig saw puzzles. it worked great-------i made a fiberglass mold from it so i would be ready to make a new one in case i ever needed one---never used the mold. (05 susuki c-50 in case anyone ever needs a fender
    [SIGPIC][/SIGPIC]
    100+ Posts
    Mar 2010
    Wheeler,Texas
    Thanks for all the input ya'll. I have already removed the luggage rack,and will see if the auto parts store carries the plastic weld.
    Feb 2008
    Anderson, Missouri
    You might try some black ABS cement and sheet of fiberglass.
    Had some cracks from the package rack on the GW1500. Picked up a 3'x3' sheet of fiberglass and a can of black ABS cement at Lowe's. (The tupperware on the 1500 is ABS - same on the 1800? Beats me.)Drilled a very small hole at the end of the crack for stress relief and glued the cacks from the inside. After gluing the cracks, filling in the holes with the ABS cement (the black stuff has a solvent with ABS plastic dissolved in it) and touching up the paint I painted the inside of the trunk with a good layer of the cement. I then pressed a layer of fiberglass into the cement. If all the fiberglass didn't turn black I brushed a little more cement on It. This is just like laying on fiberglass with ABS cement instead of epoxy. I built up the inside of the lid about 1/8", took a few layers of the glass mat. That thing is a lot stronger now, and I have no worries more cracking or using the trunk rack. Fixed a buddy's black 1500 trunk that had a crack along the ridge just above the side light. Can't even tell it's been cracekd. We did the other side and beefed up the trunk just for insurance, haven't had any more troubles.
    A few precautions - you are dealing with solvent- wear gloves, use a brush you plan to throw away for spreading the cementworing the fiberglass. Make sure there is plenty of fresh air. Don't rush, but the stuff sets up pretty quick, so plan out the job and cut the matting in advance.
    150+ Posts Bob Witte's Avatar
    Jan 2010
    Hudson, FL (near Tampa)
    Quote Originally Posted by Ozarkryder View Post
    <snip> .... After gluing the cracks, filling in the holes with the ABS cement (the black stuff has a solvent with ABS plastic dissolved in it) and touching up the paint I painted the inside of the trunk with a good layer of the cement. I then pressed a layer of fiberglass into the cement. If all the fiberglass didn't turn black I brushed a little more cement on It. This is just like laying on fiberglass with ABS cement instead of epoxy. .... </snip>
    Well said, Ozarkryder! I've done the exact same thing several times using in my case, moisture cured POR-15 primers. Those build ups & repairs have now lasted 11 years of daily driving in my 1974 VW Thing.
    Bob Witte
    The Trinity Trike
    50+ Posts
    Nov 2010
    centennial, colorado usa
    I use the star washers under the luggage rack . I have never had one crack yet.On one of my previous bikes, a prong onthe side cover broke off . I used the black abs glueon it after the primer . It never broke off,
    TOI - Michigan retdpd's Avatar
    Mar 2008
    Eastpointe
    I repaired a front fender with a putty I bought in an auto parts.
    Its siumilar to magic putty but 100X stronger. I used it as a temp fix and it held up great. I still have the fender. I rode with the fix for about 2-years then replaced it. I found a color matched one cheaper then painting the repaired one.
    I've seen the putty in many auto parts stores.
    GOOG LUCK
  1. Work in Progress - From plastic to steel
    By UglyDuckling in forum General Discussion
    Last Post: 05-28-2011, 10:59 PM
  2. Plastic Outer Shell
    By CAS in forum Stallion Trikes
    Last Post: 08-02-2010, 12:40 PM
  3. Kick Guard Plastic
    By Smoken'JOE in forum General Discussion
    Last Post: 07-25-2010, 06:04 PM
  4. Clear plastic kick plate??????????
    Last Post: 01-12-2010, 05:57 AM
  5. Chrome plated plastic
    By John Luciano in forum General Discussion
    Last Post: 12-21-2008, 09:07 AM
