Likes Likes:  5
Page 2 of 2 FirstFirst 1 2
Results 21 to 27 of 27
Thread: Raked or not raked
  1. #21
    50+ Posts
    Aurora Indiana USA
    I have ordered and received the trees. Now all I need to do is install them. My wife has terminal cancer so most of my time is spent taking care of her. So it will be quite a while before I will get them installed.
  2. #22
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    I'm sorry to hear about your wife.
  3. #23
    50+ Posts
    Aurora Indiana USA
    I lost my wife the 25th of June. I finally got my head on straight enough to have my rake kit in stalled and get my drive shaft checked. The rake is great, it handles like a dream now. They told me the splines are too loose. Now for my problem. My air ride controls don't work, and the volt meter don't work. The headlight adjust and the 4 ways do work. What could be loose that would keep the volt meter and the air shocks controls from working. The panel is pluged in and the fuse for the compressor is good.
  4. #24
    4250+ Posts
    LadyonaMission's Avatar
    Feb 2015
    San Antonio
    Sorry to hear about your wife. I can't help you with your trike problems but I can offer condolences and wish you well.
  5. #25
    May 2011
    San Angelo
    I'm so sorry to hear about your wife Bob!! That has got to be tough! RIP....
    Do you have a Motor Trike Adventure conversion? Sounds like you might. Unfortuantely, Motor Trike keeps their technical info pretty close to their chest but It sure sounds like you have a loose wire or bad switch. I rode my '06 with the Adventure kit for nearly 50,000 miles but never had that issue. The LED dispaly went bad but the control still functioned.. I don't know where the two connectors that plug in up front are connected to the kit but it must be back by the compressor. If you take the seat off I'd bet you can trace the wires. Honda switches are not very well designed so I would not rule that out either.. Good luck with the fix.
    2015 GL1800/Roadsmith HTS1800
  6. #26
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Can't help with your trike but Sorry for your loss Bob. You are in our thoughts and prayers.
  7. #27
    500+ Posts
    Feb 2008
    Planet Earth, Alpha Quadrant
    When I got my 05 new i told the dealer that i wanted to try without the rake...
    Since that time I have been through all of the twisties you can imagine. and only ONCE did I regret not having a rake. that was when I tried Kuryakin handlebar setbacks, and tried to do the West Virginia turnpike..... BIG MISTAKE.
    Took the setbacks off, and havent looked back.
    If I sell the Trike I will probably have to install a rake, because somehow folks have been convinced that they need or must have it.
    Rake...
    Never had it....
    Never will...
  1. Getting it raked tomorrow!
    By Okie in forum Honda Trikes
    Last Post: 10-06-2016, 12:33 PM
  2. How to Tell if Raked or not
    By chris vickers in forum Honda Trikes
    Last Post: 10-09-2015, 11:04 AM
  3. Raked front end
    By grimm in forum Harley Trike Conversions
    Last Post: 07-30-2014, 06:14 AM
  4. Any way to tell if trikes been raked??
    By JaysGone in forum Honda Trikes
    Last Post: 12-28-2012, 09:53 PM
  5. Been raked
    By pastence in forum Yamaha Trikes
    Last Post: 06-15-2012, 08:34 AM
