Likes Likes:  2
Results 1 to 6 of 6
Thread: Disappointments in aftermarket accessories
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Default Disappointments in aftermarket accessories
    I always find "unexpected disappointments" with aftermarket accessories. Often, the disappointments are not discovered at first. In this case, I installed Polk db501's passenger speakers 3 years ago, and am in the process of replacing them when I find cracks.
    disappointments:
    - short life, they only lasted 3 years before no more sound
    - their weight has cracked all 8 mount holes in their armrests
Size:  104.7 KBName:  DSCN8692.JPG
Size:  97.7 KBName:  DSCN8693.JPG
    Jun 2008
    Lovington, NM, U.S.A.
    Were those speakers designed to fit the Wing or an automotive sound system speaker adapted to the Wing?
    Retired trike builder
    Jun 2008
    On my 1500 trike I upgraded the speakers and matched them to the sound system on the bike and went with marine grade ones. The originals that were there were pretty much shot and sounded lousy. Back in 1993 they were probably the same ones used in Honda cars.
    JustWings.com
    May 2016
    Quote Originally Posted by trike lady View Post
    No, they are not specifically designed to fit a GL1800. They're a common upgrade many use to get better rear sound out of a GL1800. The OEM and J&M's are designed for GL1800s, but they become screachy after a while. The Polks used are marine grade, they sound considerably better, but they go bad after about 3-4 years in my climate. I'm sure the plastic breaks because of the weight of the larger magnets.
    1500+ Posts
    Oct 2012
    Batavia Ohio
    I like J&M. Great equipment.
    JustWings.com
    May 2016
    Quote Originally Posted by FRR View Post
    How long have you had your rear J & M speakers ???
  1. Aftermarket seat
    By Virg49 in forum Honda Trikes
    Last Post: 04-03-2015, 11:08 AM
  2. Aftermarket Accessories Specifically for Freewheelers - a Sticky
    By Springman2007 in forum Harley Freewheeler / Road Glide 3
    Last Post: 12-11-2014, 05:12 AM
  3. What's a good, aftermarket GPS?
    By sabretooth2 in forum General Discussion
    Last Post: 11-10-2014, 08:01 PM
  4. aftermarket exhaust
    By lasso in forum Harley Trike Conversions
    Last Post: 06-20-2014, 10:09 AM
  5. GPS/CD/Audio Aftermarket.
    By Guido Gonzeaux in forum Harley Tri Glide
    Last Post: 05-17-2011, 10:20 PM
