Likes Likes:  1
Results 1 to 10 of 10
Thread: Help identifing front forks
    Aug 2016
    Lock haven , pa., usa
    Default Help identifing front forks
    They are supposedly a Harley davidsonName:  00j0j_gAM9aHodFsm_600x450.jpg
Size:  36.9 KBName:  00V0V_1TJumlRNcQ8_600x450.jpg
    100+ Posts rrunner's Avatar
    Oct 2010
    Zuni, New Mexico, USA
    Looks like an inverted front end of some sort. It could very well be a Harley that's over length.
    Aug 2016
    Thanks..I need to get a speedometer and drive unit for this for inspection...it has neither right now
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    It could be an early Harley 8 over or something of that sort. The speedometer would depend on the front wheel.
    If it's and early Harley from wheel then it should have an area on one side or the other that the speedo assembly will fit into.
    Can you get some close-up pictures of both sides of the wheel? I might be able to identify the type.................If it's Harley.
    "Tin Man" Doug D.'s Avatar
    May 2012
    Vienna, MO USA
    I'm just throwing this out there, but it kinda looks like something I saw on the Demon Cycles site. You might cruise that and see if you find something similar. Hard for me to say for sure from the pics. If they do carry it, they should have whatever you need to get the speedo working.
    Good luck and nice ride!
    PEACE and ride safe!
    Apr 2015
    Batesville, AR. 72501
    Is it swing axle or IRS? If IRS, this will do the trick and keep the front end clean. http://www.pacificcustoms.com/ac957810.html There might be a swing axle solution available also.
    Aug 2016
    Thanks ..I will get some front wheel pics...it is a 21 inch front wheel also with a 1 inch axle
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    Bicycle speedometer dirt cheap easy install. Get the one with the wire to sensor. This starts to fade at about 70 mph but speed limit 65 around here so no problem. I've been looking for a house in pa for a while now. I'm kinda wondering how there inspection works hate to get there and not be able to use my stuff.Name:  image.jpeg
    Aug 2016
    In pa you need front brake and speedometer besides rear brakes and lights
    Aug 2016
    Default Trouble loading wheel pics
    I don't see anywhere for it to mount
  1. front forks?
    By sonny8l3 in forum VW Powered Trikes
    Last Post: 10-26-2014, 06:28 PM
  2. leading link front forks
    By stevie in forum General Discussion
    Last Post: 01-29-2013, 09:34 PM
  3. Chrome Front Forks
    By VaThumper in forum Harley Trike Conversions
    Last Post: 12-05-2011, 04:44 PM
