Likes Likes:  4
Results 1 to 3 of 3
Thread: Catching an axle seal prior to it leaking
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Default Catching an axle seal prior to it leaking
    Year: 2006 GL1800 with a Champion solid axle trike kit that was installed in 2007
    Current mileage on the ODM: 77,000
    This customer is in for a rear trike service, and an axle seal "seep" was spotted. Below shows the difference between a "weep" and a "seep." Keep in mind that many seals weep. A weep can start on day 1, or even years later. As a seal wears, a weep turns into a seep, and eventually the seep turns into a leak. If one spots a weep, of course it worth a closer inspection, but weeps can occur for a very long time and over many miles. Usually, weeps do not justify repair. But a seep is something to be concerned about and usually warrants immediate repair.
    Here is what the difference is. Weeps usually collect dust in the area, but it is a dry dust, or dust with a darker shade then other dust that is near. It is not damp. However, once a seal wears to the point of seeping, the mileage between a seep and a leak can be short. Seeps have dampness to them. Notice the wetness in the bottom picture.
    Once a seep starts to leak, drops of fluid are seen.
    The top pictures is the right side, the bottom is the left side.
    This customer is fortunate that his seep was spotted. Most GW riders want unprecedented reliability, and having such a repair done in the middle-of-no-where usually sucks.
    90+ Posts fastfreddy2015's Avatar
    Nov 2015
    I live in Pasadena, Texas
    Thanks for sharing pictures with us. Good info to have.
    200+ Posts lgjhn's Avatar
    Jun 2013
    SW Louisiana
    I've had a right side weep for thousands of miles.
    I check it pretty frequently and, so far, it has not progressed to anything worse (wet).
    My buddy's Motor Trike started leaking today. He has 120,000 on it.
    We're now researching how to get the axle out so we can change the seal.
    We'll probably change all the seals in the rear given the mileage on it.
  1. Catching up
    By Phill Griggs in forum Trike Travel
    Last Post: 10-21-2016, 09:35 PM
  2. Lehman straight axle pinion seal
    By dsifford in forum Lehman Trike
    Last Post: 10-04-2015, 11:02 PM
  3. IRS and axle seal questions
    By ny_winemaker in forum Champion Trike
    Last Post: 08-30-2015, 06:56 PM
  4. Leaking Left Fork Seal
    By Muleskinner in forum Honda Trikes
    Last Post: 08-11-2010, 11:18 PM
