Results 1 to 8 of 8
Thread: Electrical problem/question
    100+ Posts nevtat's Avatar
    Aug 2010
    Las Vegas, NV
    Question Electrical problem/question
    The trike kit adds 4 rear stop/running/turn signals. While riding today, that circuit blew a 15 amp fuse. I re-installed the ground for that circuit as the lights are mounted in fiberglass and require their own ground and installed a 25 amp fuse in that circuit. I'm thinking the 4 additional lights are drawing too much current for that 15 amp circuit, but I'm no electrical engineer. Any suggestions would be greatly appreciated. http://www.triketalk.com/forum/image...s/confused.gif
    350+ Posts Nauga Mok's Avatar
    Dec 2009
    Las Vegas, NV
    Default Re: Electrical problem/question
    Try using LED bulbs. They pull way less power than standard bulbs do. Double check your wiring for a pinched wire. The 15 amp should handle the additional load. <br />
    <br />
    NM
    Contributing Member Lunchbox1983's Avatar
    South Carolina
    15 amp should work, my guess is it was your ground. The danger with using a larger fuse is burning up your equiptment or worst your trike.<br />
    <br />
    Keep a box of extra fuses on board, as I have been able to come to the rescue of many other bikes along the way.
    LunchBox :wave4:
    GL1500 RoadSmith
    Wife:
    2009 Stallion #580
    Candy Apple Red
    <div class="bbcode_quote">
    <div class="quote_container">
    <div class="bbcode_postedby">
    <img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>nevtat</strong>
    <a href="showthread.php?p=42083#post42083" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
    </div>
    <div class="message">The trike kit adds 4 rear stop/running/turn signals. While riding today, that circuit blew a 15 amp fuse. I re-installed the ground for that circuit as the lights are mounted in fiberglass and require their own ground and installed a 25 amp fuse in that circuit. I'm thinking the 4 additional lights are drawing too much current for that 15 amp circuit, but I'm no electrical engineer. Any suggestions would be greatly appreciated. <a href="http://www.triketalk.com/forum/images/smilies/confused.gif" target="_blank">http://www.triketalk.com/forum/image...s/confused.gif</a></div>
    </div>
    </div>
    </div>the problem with putting a 25 amp fuse on a 15 amp circuit is that you can allow the wire to heat up from pushing to much power thru to small guage wire. its like a toaster thin wire high current. if in act you need the higher current draw then some type of redesign of the power feeds would be necessary. as suggested use led bulbs to lower demand.
    Aug 2010
    Las Vegas, NV
    Thanks for all your ideas. Of course using the 15 amp fuse is the best way to go. These electrical problems make me realize my limitations, as Clint Eastwood would point out. Anyway, it was my big fat butt that was causing the problem. When I bounced on the seat I was also making the seat pan strike the connectors under it causing the short. I re-routed the connectors/wires and all is well.
    South Carolina
    Glad you found it, shorts, and or connection problems can drive you insane trying to find them. What's the old joke it always the last place you look.
    LunchBox :wave4:
    GL1500 RoadSmith
    Wife:
    2009 Stallion #580
    Candy Apple Red
    Quote Originally Posted by nevtat View Post
    good job finding the short
    Aug 2010
    Las Vegas, NV
    Default Re: Electrical problem/question/Update
    Took the trike out this morning and blew the fuse again within 1/2 mile of the house. Spoke to my "cage" mechanic and we added the current draw of all the lights supported by that one 15 amp fuse. It's no wonder it kept blowing! The addition of four incandescent bulbs was too much for that circuit. I changed all five rear stop/running tail light bulbs to LED and I can't get that fuse to blow. <br />
    Today's road test proved the point, no blown fuses. <br />
    <br />
    That one circuit supports the head light, both driving lights, the front turn signal running lights, and all five rear stop/running bulbs. If a guy wanted to continue to use the incandescent bulbs, he could re-wire the stop/running lights to their own fused circuit. <br />
    <a href="http://www.triketalk.com/forum/images/smilies/no.gif" target="_blank">http://www.triketalk.com/forum/images/smilies/no.gif</a>
  1. Really stupid electrical question
    By mikestrike in forum Harley Trike Conversions
    Last Post: 07-06-2013, 08:30 AM
  2. Electrical Issues
    By IN Skuter Dude in forum Honda Trikes
    Last Post: 04-07-2012, 12:47 PM
  3. I have an electrical problem! Help!
    By Boscoporp in forum General Discussion
    Last Post: 04-01-2010, 03:57 PM
  4. electrical problem, volt meter in 12v range
    By silverdevil in forum Stallion Trikes
    Last Post: 03-12-2010, 11:50 PM
  5. Electrical Problem - Blowing Fuse
    By patriot in forum Honda Trikes
    Last Post: 10-15-2009, 08:50 AM
