Likes Likes:  6
Results 1 to 5 of 5
Thread: Electric fuel pump pressure
    "Tin Man" Doug D.'s Avatar
    May 2012
    Vienna, MO USA
    Default Electric fuel pump pressure
    Here to pick a brain or two again...
    Ok, I have an 1835 with a W-100 cam and a Weber 32/36 progressive carb. I need an electric fuel pump, as the engine was built on a "late model" AS21 AJ case originally made for a fuel injected engine with no provision for a mechanical pump.
    So...
    What is the optimal fuel pump pressure for a set-up like this, and, is there an electric pump out there that won't require a regulator? My best guess was a pressure of 3.5-4 psi. I'd like to avoid the regulator, both for the additional expense and space considerations.
    I've found pumps advertised to run at this pressure range and claim to need no regulator, but before I pull the trigger and wind up with something that doesn't work properly and pisses me off even more than a busted end casting stud, I thought I'd ask here first.
    Thanks in advance!
    PEACE and ride safe!
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    I dont know of a decent internal regulated pump.
    I always used a little faucet clicker pump and a seperate pressure regulator.
    3.5 psi is the high end.
    I ran 3 psi on my carbs.
    Maybe there is something else.
    Shop around.
    Check with John at aircooled.net
    May 2012
    Vienna, MO USA
    Thanks Rex, much appreciated!
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    I am not sure what PSi my pump is but I have my regulator set to 3.5
    Thank you
    Bob
    May 2012
    Vienna, MO USA
    Facet clicker at 4-7 psi and a dial type regulator, which I'll start out at 3.5 psi and tune from there.
    Thanks guys, for all your help and advice! Very much appreciated!
  1. Fuel pump help
    By Nighttrain in forum VW Powered Trikes
    Last Post: 09-06-2016, 10:29 PM
  2. electric pump for autostick tranny fluid
    By rbourne3 in forum VW Powered Trikes
    Last Post: 04-18-2015, 09:08 PM
  3. fuel pump
    By samsonone1 in forum Honda Trikes
    Last Post: 06-06-2013, 11:52 AM
  4. Fuel Pump
    By bigjoey38 in forum VW Powered Trikes
    Last Post: 06-12-2012, 12:55 PM
  5. Ok,Gravity or electric fuel pump?
    By warnerrd in forum VW Powered Trikes
    Last Post: 10-15-2010, 10:46 PM
