Results 1 to 9 of 9
Thread: Driver intercom transmit issues.
    350+ Posts
    Jul 2016
    N Ky USA
    Default Driver intercom transmit issues.
    Driver headset intercom quits transmitting occasionally. I hear music, CB, my passengers voice but I don't have transmit. Everything will be working properly an then suddenly it quits. I tried swapping out the lower cord with wifes but same issue. I haven't had an opportunity to swap helmets with a known working one. It's raining today so I thought maybe someone might have had this issue and point me to a connection/connector on the bike to look for corrosion etc. Thanks.
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    If it's a Tri-Glide, push to talk button contacts oxidized
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Do you have cb and is it a Hondaline ???
    Most all problems like that are related to the helmets or cords. In your checking, don't forget that most helmets have a short cord that is attached to the helmet ???
    Jun 2010
    Indianapolis, In.
    Since you hear everything and you switched lower cords, it's most likely you mic has a problem.
    Had to replace the mic on my J&M headset some time ago.
    What brand headset? You can buy a new mic for most
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    350+ Posts
    Jul 2016
    N Ky USA
    Left that out, Sorry its a GoldWing
    Quote Originally Posted by GoldWingrGreg View Post
    Yes, I do have a Hondaline CB that was recently installed. Stay tuned I might have a standing wave question). My intercom issue was present prior to the installation of the CB.
    I strongly suspect my headset. For some reason the boom Mike gets twisted in either the removal or putting on of this helmet. Then as I go to turn it so the proper side is toward my mouth Many times I've actually turned it the wrong way an now I'm talking into the back side of the mike. In this process I might have actually twisted it around maybe several times!
    My headset is a J&M.
    JustWings.com
    May 2016
    Quote Originally Posted by Bronson512 View Post
    When is someone gonna make a boot that is indexed so we all know which way the mic needs to face ??? Just say'n !!!
    May 2011
    San Angelo
    Unless they have changed again J & M is. The sock is flat on one side and that it where the mic is suppose to be. All of mine are that way....
    2015 GL1800/Roadsmith HTS1800
    350+ Posts
    Jul 2016
    N Ky USA
    Quote Originally Posted by Gold Rush View Post
    If I take the wind sock off my mic has two flat sides but I've never noticed the sock or boot being anything but round! My boots may be a replacement model but as many times as I've had to crank that thing around to get it oriented I would have noticed.
    350+ Posts
    Jul 2016
    N Ky USA
    The wife and I took a ride yesterday and not too many minutes into out ride my intercom went out AGAIN. As I mentioned previously I can still hear everything else just no intercom transmit from my headset. We ruled out a faulty helmet headset yesterday as a working unit was plugged into the GoldWing plug and all worked fine. I was without an intercom till we went over a bridge where the transition was rough then it started working and worked all day. That tells me I've got a connection or ground problem.
    What/Where are the connections I need to check first.
  1. Need Help with Intercom
    By gpdstaffcapt in forum Harley Tri Glide
    Last Post: 06-15-2016, 07:49 AM
  2. Intercom Noise
    By deuce1959 in forum Honda Trikes
    Last Post: 07-13-2012, 08:00 AM
  3. Intercom
    By drumdoctor in forum Accessories
    Last Post: 10-23-2011, 09:00 AM
  4. CB transmit
    By minnleeboy in forum Honda Trikes
    Last Post: 04-09-2011, 11:28 AM
  5. Intercom
    By Goldwing09 in forum General Discussion
    Last Post: 09-22-2010, 08:28 AM
