Likes Likes:  4
Results 1 to 10 of 10
Thread: Trike and checking your oil
    30+ Posts Mcgee10's Avatar
    Apr 2017
    Rockford, MI USA
    Default Trike and checking your oil
    On my bike with a warm up engine my oil was checked on the jiffy stand NOT upright. So after the trike kit it's always upright. I was not thinking when I did this.
    I just changed all 3 before the kit was added. Just something to think about.
    Ride on
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    No fowel, use a turkey baster with a hose extentions if it's over filled. All good
    Apr 2017
    Rockford, MI USA
    Thanks that a great idea.
    Ride on
    Just wondering if you checked the oil with the bike on the Kickstand [I refuse to call it a Jiffy stand]
    Why would the oil be too high when you have the bike in the up right position.....
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by Mcgee10 View Post
    Just clean it good before putting it back in the kitchen for the wife to use next.
    I ended up getting Mary a new one, since I could not clean it to her satisfaction. Now I have one permanently in my shop.
    www.DKCustom.com
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Default Jiffey stand
    Mr Davidson must of been on schrooms that day . Jiffy muffin and cornbread is all i can relate it to . 📞
    Jun 2008
    Lovington, NM, U.S.A.
    I never could quite understand why they call it a 'Jiffy' stand either, my mind does wonder over to Jiffy Cornbread/Muffin Mix also. It could be an 'Iffy' if'n you don't make sure it is locked forward when the bike is parked on it.
    Retired trike builder
    250+ Posts
    Nov 2013
    homossasa fl usa
    The oil level will be higher on the dip stick if not on the sidestand. Yeah, I can't call it a jiffy stand either and I still call it a crash bar not an engine guard. I leave 1 rear wheel on my driveway to get the angle as if on a kickstand when I check oil level.
    gerald martin
    Guest
    Default checking oil
    If it was my trike I would find a bike without the trike kit and check the oil level when warm and with the correct amount of oil in it, then I would stand it straight up, see where the oil level was on the dipstick then mark that level on the trike dip stick then you would be set
  11. #10
    20+ Posts mr.precision's Avatar
    May 2017
    Fountain Hills, Arizona USA
    Just changed the oil and filter on my 2005 FLHTC Lehman trike.
    Owner's book says 4 quarts.
    Factory shop manual says 3-1/2 quarts.
    I put in 3-1/2 quarts, checked it hot. Comes up to within about 1/4" of the top full mark, with the dipstick oriented to drop straight down with the plug pushed all the way in.
  1. Checking in
    By Fabricater in forum General Discussion
    Last Post: 03-29-2017, 08:14 PM
  2. Checking the oil
    By 2blackbelts in forum VW Powered Trikes
    Last Post: 05-20-2012, 01:05 AM
  3. just checking in...
    By HouseFire in forum New Member Introductions
    Last Post: 11-30-2011, 10:05 AM
  4. jus checking it out!
    By shinysideup in forum New Member Introductions
    Last Post: 09-23-2011, 06:41 PM
  5. Checking the OIL after TRIKE Conversion
    By KRUZR in forum Harley Trike Conversions
    Last Post: 05-11-2011, 01:20 PM
