Likes Likes:  2
Results 1 to 5 of 5
Thread: Oil Press/Temp Sending Unit
    "Tin Man" Doug D.'s Avatar
    May 2012
    Vienna, MO USA
    Default Oil Press/Temp Sending Unit
    This is for the guys running this type of oil pump with a spin-off filter.
    Has anyone put a sending unit in the port just behind the filter? Did you have any trouble with the sender restricting oil flow to/from the filter? This one came with long block I just bought, but there wasn't any documentation with it. Can't seem to find an answer in any of the descriptions on the various sites that sell these.
    Thanks!
    Peace and ride safe!
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    I dunno.
    With the placement of that boss it make me wonder if something is in there.
    Looks like an ideal place for an over pressure relief valve to protect the filter on cold start.
    Look in there and see. I have seen others that had a port for accessory use.
    Meme Master
    Jan 2014
    Farmington, NH USA
    I'm not sure what that SHCS is on the side of the pictured adapter is either, sorry. I agree w/Rex, in that it is likely a pressure bypass of some type.
    I'd try going back to the builder you purchased the engine from for info on the filter adapter, maybe.
    Is there no port on your block where the factory oil pressure sending unit was once mounted?
    I'm not sure you could place a temp sending unit in that area, as well as the oil line to your pressure gauge.
    Are you planning on mechanical or electric gauging?
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    on my engine my Oil pressure sending unit is as shown below (see it just below the cooler in the diagram) and my Oil temp sending unit is is at location 1 Its the cap nut for the Oil pressure relief valve
    Thank you
    Bob
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    I think it's like what Rex stated. That has a relief check ball in the filter housing. I believe it's a little ball and spring............If my memory serves me correct. I don't think it would be a very good idea to put a pressure gauge in there.
    However, you could pull the plug, as Rex said, and check to make sure.
  1. Thanks to all of you for sending your prayers.
    By goldwingagain in forum Thoughts & Prayers Sanctionary
    Last Post: 12-10-2016, 05:33 PM
  2. CAUTION SPAMMER SENDING PMs! Do not click link!
    By Papa Zook in forum General Discussion
    Last Post: 08-11-2016, 11:55 PM
  3. Fuel sending unit???
    By DblTrbl in forum Yamaha Trikes
    Last Post: 06-23-2015, 02:43 AM
