Likes Likes:  13
Results 1 to 20 of 34
Thread: @#$%^&* Torx Screws !
    150+ Posts mirider's Avatar
    Jun 2015
    West Michigan
    Default @#$%^&* Torx Screws !
    Having a devil of a time trying to install my trailer hitch on the TriGlide. Step 1 is to remove the two T40 Torx screws on the back cross frame member. Supposedly, these are locktited so the instructions say to heat the screw with a torch first. Well, after 3 or 4 attempts, I have had no luck and cannot get them to budge. Anyone have any thoughts or suggestions on how to proceed.......
    Dave
    14 HD Tri Glide
    H.O.G. Member
    Quote Originally Posted by mirider View Post
    Heat and a hammer/drill screw gun....That should shock them off...
    800+ Posts Motorcycle Mike's Avatar
    Jul 2014
    Lawrenceville, Ga
    Impact wrenches, either air or electric, work wonders.
    You don't quit riding because you get old.
    You get old because you quit riding.
    Mike & Shirley
    200+ Posts
    Apr 2017
    Murphy, Texas, USA
    I removed mine without heat. I installed a hitch master and they provided and torx ratchet socket. It took some effort, but they broke free. The hardest part for me was re threading the back muffler bolt. Took me an hour on one of them.
    1000+ Posts Texan's Avatar
    Jun 2013
    Texas
    Removed mine with an electric impact with no problem. No heat.
    8~\o
    Jun 2015
    West Michigan
    Thanks to all for the tips and comments. Since I don't own an impact wrench, guess a visit to my dealer is in order. Was hoping I could handle this install without help, it is fairly straightforward once those dang screws are out.........
    Dave
    14 HD Tri Glide
    H.O.G. Member
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    I'm thinking the cost of an impact wrench will be less than what the dealer will charge you...plus in the end you will have the work done, AND own an impact wrench.
    www.DKCustom.com
    80+ Posts 8Crow's Avatar
    Nov 2013
    New Brunswick, Canada
    Try a soldering gun tip to the screw head. More concentration of heat than a torch and less chance of over heating surrounding areas.
    Very good point from Kevin about the cost of an impact gun....
    Good luck.
    Doug
    gerald martin
    Guest
    Default screws
    why not just rent a impact wrench for a few bucks Also if you take it to a dealer they might flag your warranty (if you still have one that is ) for installing a trailer hitch
  11. #10
    Just me... If i need a tool even if i think it will be used just once , I buy it if you live long enough and work on things you'll find a use for it again...You can get a drill gun and a drill driver combo 18v for under a hundred...
  12. #11
    5250+ Posts Pegasus1300's Avatar
    Spring City,Utah, USA
    If you have the ability always buy the tool. It's going to cost you either way,but in buying the tool you only have to pay for it once.
    Happy TRAils/NSD
    Paul
  13. #12
    Dead animals deserve balloons... MikeyTX's Avatar
    May 2016
    Big Bend Country, TX
    Is there a Home depot or Lowes in close proximity ? They do rent tools. Other option would be a body shop or car repair shop. You'd be surprised what can be accomplished with a crisp $20 bill.
    2021 Mustang GT Premium A10 Handling Pkg
    Red White and BBQ Texas, it's whole whole nother country .........
    [SIGPIC][/SIGPIC]​
  14. #13
    Jun 2015
    West Michigan
    Will see if I can beg, borrow, or steal (well maybe not steal) an impact wrench and go from there......
    One additional question.....do the mufflers have to be moved? With their position, doesn't seem to be a straight shot at the screws. If so, what is the method to move them.
    Dave
    14 HD Tri Glide
    H.O.G. Member
  15. #14
    200+ Posts
    Apr 2017
    Murphy, Texas, USA
    I removed both muffler hanger bolts on each side and loosened where the mufflers clamp to the pipes. That gave me enough room to get the torx socket on the torx bolt after moving the mufflers. I did not have to remove them, but just reposition them to make the access. Rethreading the back bolt was very difficult but once you get it threaded a box end wrench works fine.
  16. #15
    Jun 2013
    Texas
    I'm thinking the cost of an impact wrench will be less than what the dealer will charge you...plus in the end you will have the work done, AND own an impact wrench.Kevin
    You can pick up an electric impact at Harbor Freight for less than $60.00.
    That way you'd own one for the next project......
    https://www.harborfreight.com/catalo...lectric+impact
    8~\o
  17. DKCustoms postbit
  18. #16
    May 2016
    Poor maligned TORX head bolts and screws. What would we have to cuss about with our many projects we endeavor to install on our trikes. How boring would life be ? Oh ............ Wait ........... Then the 'ol lady would figure that with all the extra time on my hands I could help her around the house .....................................
    [SIGPIC][/SIGPIC]​
  19. #17
    Quote Originally Posted by MikeyTX View Post
    Remember the Wife rules....And you have to have Rules, Otherwise we would all be having way too much fun...
  20. #18
    May 2016
    But why is it that my rules always seem to be overruled by her rules ?
    [SIGPIC][/SIGPIC]​
  21. #19
    1250+ Posts Sloufoot's Avatar
    Jul 2012
    Chubbuck Idaho
    Remember to have the torx bit fully into the screw head & held straight with a bit of pressure on it before you pull the trigger on the impact wrench or you will be exercising a few more expletive & loud verbiage !
  22. #20
    Thats the Rules........Can't tell you why, I Don't make them..
  1. 2014 brake caliper bolts are FEMALE E-TORX
    By Beorn of Ga in forum Harley Tri Glide
    Last Post: 09-09-2015, 08:03 AM
  2. Problem with Derby Cover Screws
    By eforman48 in forum Harley Trike Conversions
    Last Post: 08-16-2013, 02:10 PM
