2008 Lehman Tramp Rear Brake Master cyl
Dec 2, 2012
60
17
Big Spring Texas
I have a 2008 Lehman Tramp (Suzuki C50) with a leaking Rear brake Master Cylinder. Does anyone have any info on replacement Cyl are repair kit. I cant find anything on it.
Any help would be appreciated
The stock C-50 two wheeler has mechanical brakes on the rear. When converted it went to hydraulic brakes. Inspect the line from the M/C reservoir to the M/C to make certain the line is not leaking. Lehman part number is GB6210 for the M/C. I will check today to see what the crossover is and if there is a repair kit and then get back to you.
The Lehman Tramp has a cartridge type M/C for the rear brakes (GB6210).
A rebuild kit is $50.00 and a complete M/C is $117.00, and both are readily available.
Proud Texan
I drove up to Champion Trikes today and was talking to a sales rep about your brake problem and was told the M/C on your trike is a HD part. No. 42446-87B. He gave me another number and said it was another M/C used by Lehman but when I looked it up it comes up as a brake pedal. That no. is 42502-90B. Lehman is now owned by Champion Trikes.
I finally got a chance to ck on the leak in my MC. Jim Murphy was right. It was leaking on the connection going into the top of MC from the reservoir. Fixed that and bled the brakes again and all is ok now. Thanks every one for the help.:clapping::pepper:
Hello Jim,
I am going to call you today to see if this cartridge will work on my 2007 C90. Do you know who supplies the parts to rebuild these? I just really need the piston cup and O-ring.
Thank you,
JamesFW
JamesFW
