Likes Likes:  8
Results 1 to 11 of 11
Thread: 2008 Lehman Tramp Rear Brake Master cyl
    60+ Posts ProudTexson's Avatar
    Dec 2012
    Big Spring Texas
    Default 2008 Lehman Tramp Rear Brake Master cyl
    I have a 2008 Lehman Tramp (Suzuki C50) with a leaking Rear brake Master Cylinder. Does anyone have any info on replacement Cyl are repair kit. I cant find anything on it.
    Any help would be appreciated
    Dec 2012
    Santee
    It probably is the stock Suzuki M/C. Look at the Suzuki parts list for repairs.
    Ray
    2017 Harley Triglide
    Tijuana Border
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by ProudTexson View Post
    The stock C-50 two wheeler has mechanical brakes on the rear. When converted it went to hydraulic brakes. Inspect the line from the M/C reservoir to the M/C to make certain the line is not leaking. Lehman part number is GB6210 for the M/C. I will check today to see what the crossover is and if there is a repair kit and then get back to you.
    Jim Murphy
    Iron Butt Rider 2001
    Martinsburg, WV
    The Lehman Tramp has a cartridge type M/C for the rear brakes (GB6210).
    A rebuild kit is $50.00 and a complete M/C is $117.00, and both are readily available.
    Jim Murphy
    Dec 2012
    Big Spring Texas
    Thank you sir. Does Lehman have a parts website. Are do I need to call them. I think it would worth it to buy the complete M/C.
    Martinsburg, WV
    I doubt that anyone at Lehman/Champion could help, but you could call them.
    If they can't help you, call me @ 304-262-6200 SAT 9am-1pm ET
    Jim Murphy
    Dec 2012
    Big Spring Texas
    Thank You so much for the help. I will keep you posted on what I find.
    Dec 2012
    Santee
    Proud Texan
    I drove up to Champion Trikes today and was talking to a sales rep about your brake problem and was told the M/C on your trike is a HD part. No. 42446-87B. He gave me another number and said it was another M/C used by Lehman but when I looked it up it comes up as a brake pedal. That no. is 42502-90B. Lehman is now owned by Champion Trikes.
    Ray
    Tijuana Border
    Dec 2012
    Big Spring Texas
    I finally got a chance to ck on the leak in my MC. Jim Murphy was right. It was leaking on the connection going into the top of MC from the reservoir. Fixed that and bled the brakes again and all is ok now. Thanks every one for the help.
    60+ Posts
    Apr 2016
    Monroe, NC , Union
    Hello Jim,
    I am going to call you today to see if this cartridge will work on my 2007 C90. Do you know who supplies the parts to rebuild these? I just really need the piston cup and O-ring.
    Thank you,
    Martinsburg, WV
    ^ handled !
    Jim Murphy
  1. Master cylinder for rear brake
    By jimmib in forum Harley Trike Conversions
    Last Post: 07-15-2020, 12:49 PM
  2. Rear brake master cylinder reservoir idea
    By Dirtydan in forum Victory Trikes
    Last Post: 08-03-2016, 09:40 PM
  3. Rear Brake Master cylinder
    By Kiwi in forum New Member Introductions
    Last Post: 02-05-2016, 11:28 AM
  4. rear brake master cylinder spec needed
    By lardarse in forum Harley Tri Glide
    Last Post: 12-31-2013, 03:18 AM
  5. Rear Brake Master?
    By LadyKitty in forum Tires, Wheels, Brakes, Front End
    Last Post: 11-19-2011, 09:26 PM
