Likes Likes:  0
Results 1 to 16 of 16
Thread: Andre
    10+ Posts
    Sep 2010
    SOUTH AFRICA
    Smile Andre
    Hi to you all. I am from south africa and would like to know if any of you know gene neill who created a vw trike called the "devils due" he is from florida usa. I need some technical info as i am in the prosess of building my own trike and his frame caught my eye. Here in south africa is no to none info on trike building hope there is some help on this forum
    7250+ Posts Nana's Avatar
    Apr 2008
    Ohio
    Default Re: Andre
    Hi Andre, I don't believe Gene Neill is a member here, but we have several members who have built the VW trikes for themselves, so hopefully someone can help you out.
    Trike Talk Membership Map
    No matter the storm, when you are with God, there is always a rainbow waiting.
    http://i440.photobucket.com/albums/q...andana-1-1.jpg
    10+ Posts
    Sep 2010
    SOUTH AFRICA
    Default Re: Andre
    thank you i will ask as i go allong with my project
    Tour Captain
    Jan 2010
    Default Re: Andre
    Hello,<br />
    i think he has passed away awhile back, you may try google, i think he had a website somewhere,<br />
    ray
    VW Tech Expert Loner's Avatar
    Aug 2010
    Harvest, AL USA
    Default Re: Andre
    Gene Neill did pass on last year. He did some nice work on his bright yellow trike - and then didn't even get to really ride it other than a basic test drive.
    /Loner
  6. #6
    TOI -Virginia KDHUFF's Avatar
    Feb 2010
    millboro, va
    Default Re: Andre
    I remember seeing the trike in some web searchs I did but nothing showing the build in progress. coulda been there but I did not see anything
  7. #7
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Default Re: Andre
    Quote Originally Posted by andre View Post
    Welcome aboard Andre. Glad you found us.
  8. #8
    10+ Posts
    Sep 2010
    SOUTH AFRICA
    Default Re: Andre
    Thanx for all the replies. It is sad to here that Gene passed on but that is life.
  9. #9
    10+ Posts
    Sep 2010
    SOUTH AFRICA
    Default Re: Andre
    Hi
    I have started my trike build will post some pics. One question, if i use a stock suzuki 650 front end, will a rake of 45 degrees work or is it to much as the standard rake on the bike is 32 degrees? The head hight is 90 cm. Do you think the trail will be to much? Hope you guys can help me
  10. #10
    Aug 2010
    Harvest, AL USA
    Default Re: Andre
    It has been my experience that most all of the hydraulic 'tube type' front ends will stop compressing and depend on tube flex at rake greater than 37-38 degrees. Beyond that, yes, 45 degrees with a straight tube front end will give you too much trail to be easy to steer. You might consider long handlebars (to add leverage to compensate for the long trail), or perhaps a springer style front end. This number will vary by a couple of degrees either way depending on opinions, but I've found that 35 degrees or so is about as much as you can get away with without having steering problems.
  11. #11
    100+ Posts rrunner's Avatar
    Oct 2010
    Zuni, New Mexico, USA
    Default Re: Andre
    I had to build my own leading link front end because the standard Yamaha front end I had on it had too much trail and was hard to steer. I have my leading link at 35 degrees and a trail of about an inch. I love the result.
  12. #12
    10+ Posts sdewolfe's Avatar
    Jul 2011
    New Caney, TX, USA
    Default Re: Andre
    Andre,
    Gene and I corresponded for awhile. I sent him a hand drawn wiring diagram because he was having some issues with his wiring.
    To see his trike go to:
    Internet Archive: Digital Library of Free Books, Movies, Music & Wayback Machine
    Enter this url in the Wayback machine:
    vwtrike.net
    It will pull up a page that shows the dates that their spiders captured Gene's site. It works OK. But, some things escape the spiders so there will be some broken links or missing photos. Try several different dates because the changes made after each saved point will be reflected in the next saved point. Sometimes you find information that would otherwise be lost.
    Gene documented the entire build, including photos of the frame from raw steel to finished product.
    Good luck with your build!
    Regards,
    Mr. Shannon DeWolfe
    --I've taken to using Mr. because my name misleads folks on the WWW. I am a 62 year old fat man.
  13. #13
    20+ Posts Wayne D's Avatar
    Jun 2011
    Whitaker Pa.
    Default Re: Andre
    That was great sdewolfe, I remember reading that site from end to end some years back. I learned lots of valuble information from Gene's site.
  14. #14
    10+ Posts
    Sep 2010
    SOUTH AFRICA
    Default Re: Andre
    Thank you for the advise. The rake is set at 40 degrees only time will tell if this was the wright option.
  15. #15
    10+ Posts
    Sep 2010
    SOUTH AFRICA
    Default Re: Andre
    Some pics of my first trike build
  16. #16
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    Default Re: Andre
    nice start good luck
