Results 1 to 5 of 5
Thread: New front tire
    700+ Posts kybigmac's Avatar
    Oct 2014
    murray.ky usa
    Default New front tire
    I have a 08 RSV/Hannigan kit and in need of a new front tire and was wondering if anyone was using the Avon trike tire that is made for the Harley. Cross referencing says it is almost the same size as the original tire. When I had my Goldwing trike I used one of the "trike tires " on it and liked the way it performed, but only got about 10k out of it.When I got this trike it had the original Dunlop 404 with 10k miles and was worn out but had worn very well, so I decided to try a 404 rear thinking it would last longer with the deeper tread. Now at 20k the tire is cupped badly and needs replacing. So I'm asking for some opinions on front tires! The Harley 'trike tire' is bias ply and 9/32 instead of radial 6/32 like the one for the Goldwing, so it might last longer. All opinions are appreciated!
    550+ Posts Gideon's Avatar
    Dec 2012
    Indianapolis, IN. USA
    Quote Originally Posted by kybigmac View Post
    If you got 20,000 miles of good service out of the D404, why do you want to change to another tire?
    The D404 is inexpensive and preforms well.
    Ride Safe & God bless
    Oct 2014
    murray.ky usa
    Quote Originally Posted by Gideon View Post
    I like the way it rides and it is inexpensive, but the 2nd one that I put on cupped really bad. It started cupping at about 3k and has worn very uneven and is very noisy! The only difference between the two is that one was a front tire and the other is a rear tire.
    I'm just looking for other options.
    Dec 2012
    I am using a D404 Rear Tire in a reverse rotation. I check the air pressure regularly, keeping it at 42 lbs. Present tire has 20,000 mile with no cupping.
    I heard good things about the Avon Trike Tire. However, my dealer said they couldn't get it in the size I need.
    100+ Posts steamer's Avatar
    Jun 2011
    romulus ny,usa
    I ran a Metzler 880 for over 20000 miles. I could have run another season, but it was 4 years old and starting to dry out. Keep in mind my RSV is mated up to a Motortrike with no rake. I change over to a metzler 888 this year.
  1. Avon AV-71 Front Trike Tire - anyone using this tire???
    By dadztoy in forum Outrigger Style Trikes
    Last Post: 02-16-2024, 04:24 PM
  2. Front tire
    By kybigmac in forum Yamaha Trikes
    Last Post: 10-20-2016, 11:08 PM
  3. New Front tire
    By Thomas L in forum Honda Trikes
    Last Post: 04-02-2015, 05:05 PM
  4. tire size for rear tire on front? 2007 goldwing trike
  5. Front Tire
    By wwalton259 in forum Harley Trike Conversions
    Last Post: 11-26-2014, 12:36 AM
