Likes Likes:  21
Page 2 of 2 FirstFirst 1 2
Results 21 to 36 of 36
Thread: wheel falls off ? ? ? ?
  1. #21
    gerald martin
    Guest
    Default wheels
    Just remember over torqueing is bad also. It can stretch the threads and the studs could break. I always take my bike to Kal Tire they will torque them for free and they calibrate their torque wrenches every morning. Also you will be watching them do it
  2. #22
    600+ Posts ISP-FL's Avatar
    Mar 2017
    Lake Suzy, FL USA
    Having owned numerous cargo trailers and traveling in 5th wheels over the years, torquing lug nuts is normal maintenance, especially when new. Never really thought about it on TG but I certainly will now. I agree that it probably isn't something you want to trust to a busy Harley dealership tech.
  3. #23
    250+ Posts
    Nov 2012
    Bradenton, FL.
    Cool
    Thanks for the heads up, I installed the lift kit and forgot to re check the lugs, All good Thanks Doc
    2019 Red and Silver Tri Glide
  4. #24
    2500+ Posts trikermutha's Avatar
    Oct 2010
    USA
    Quote Originally Posted by Keystone View Post
    I might know a thing or two about that....
    It's not a Harley issue as in the MoCo. This happens to cars/trucks too. If they are not properly torqued they can come off anywhere from a few miles to 1k miles later. This happened to me 6 years ago. That dealership hasn't received any business from us since.
    Man I remember this when it was posted years ago..That was scary
  5. #25
    350+ Posts
    RickDeVon's Avatar
    Jun 2010
    Pine Mountain,Ga
    I don't torque wheels on the trike or my cars and trucks...I service them all at 5ooo miles...rotate the cars and trucks wheel and use a 4 way lug wrench to tighten them...check the trike at each service....been doing this since I was 16 and never a problem...
    Miss Mysterious...
    2015 Mysterious Red Tri Glide...
    Vance&Hines head pipe w/Rhinehart slipons...Slipstream Collection...DK Lift...11" Clearview w/ recurve...HD chrome Enforcers w/Goodyear Triple Tread Assurance...just a touch of chrome & LEDs...
  6. DKCustoms postbit
  7. #26
    Sep 2016
    Springfield, Mass. USA
    Thanks for the heads up...........I'm going out to the garage now!
    Doing the tail of the dragon in two weeks..........thank you!
    Ronnie
  8. #27
    40+ Posts
    Oct 2015
    NUNYA
    I drive a big truck and every time I have a tire removed and replaced I have to sign a form stating I understand lugs must be retorted at between 100 and 500 miles. It's not Harley thing. It's across the board on everything.
  9. #28
    100+ Posts 470004's Avatar
    Sep 2013
    Astoria, New York, USA
    I always check the torque (95 ft lbs) and air pressure each time before a ride. It only take a few minutes.
  10. #29
    5+ Posts
    Jun 2017
    Chambersburg, PA, US
    Quote Originally Posted by hddocfl View Post
    Yup same here. I'll be checking mine tonight too. It's very sad that this subject comes up when someone died from it, but very good that it comes up and so many of us realize that we've neglected to check our own. Your friend obviously did not die in vain. God bless those who have gone before us to keep us safer.
  11. #30
    600+ Posts 427dave's Avatar
    Jan 2011
    The Villages, FL
    I believe Keystone, a moderator here, had one of his rear wheels come off his Tri-Glide while riding it...this was a few years back. I'm sure he'll correct me if I am mis-remembering.
    I NEVER trust the dealer to torque them down correctly.
    I always retorque mine after 50 miles....I think the manual says after 100 miles.
    I also check them periodically. Just did it yesterday morning before leaving on our trip.
    I retorque mine when it comes back from the dealer everytime. They have been loose one time. Anytime I remove a rear wheel I will retorque it after 0-100 miles. Good practice. I had heard of a wheel coming off on a Triglide around Tampa quite a few years ago and the passenger died.
    Rear lift kit, and tour pak relocation, Road Zepplin Air seat, Chrome front forks, SE 120 ST engine, Headers by V&H, Stock mufflers, SE 259E cams, TTS tuner and SE Air Cleaner, 58 mm Throttle Body, Tank lift, Wind Deflectors, DIY Crankcase Breather, Floorboard Ext.
    Amateur Radio : W4WNG
  12. #31
    100+ Posts
    Sep 2015
    Lexington
    Any recommends for a good torque wrench and instructions on how to use it? I'm a mechanical idiot, but this sounds like something I should do myself.
  13. #32
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Quote Originally Posted by Fredward View Post
    Sears Roebuck
    All torqued up and ready to roll
  14. #33
    650+ Posts
    Sep 2015
    Sheboygan, WI
    Checked mine today, all good!
    It is what it is.
    16 Tri Glide vivid black
  15. #34
    Sep 2014
    Box Elder, SD
    Checked the lug nuts yesterday. Right wheel all good, left wheel, 3 were spot on, 1 was not. About 1/4 turn before it torqued. Glad I checked the lug nuts and I will be doing it a little more often.
  16. #35
    10+ Posts
    Oct 2013
    Frisco, Tx
    I got got mine at Harbour Frieght. Buy 1/2 Torque Wrench for $10, then get a extension and deep socket (3/8)
  17. DKCustoms postbit
  18. #36
    1250+ Posts
    ultrafxr's Avatar
    Aug 2017
    Lakeland, TN
    Quote Originally Posted by Harleyrider2810 View Post
    I've had only one trike - my 2018 TG but unless something has changed the lug nuts are 3/4". Well actually they are 19mm but 3/4" is close enough for those who don't have metric sockets.
  1. 16x5.5 inch rear wheel converted to dual dics front wheel
    By irmagoo in forum Tires, Wheels, Brakes, Front End
    Last Post: 01-15-2022, 08:29 PM
  2. Replies: 5
    Last Post: 12-08-2014, 01:03 AM
  3. Niagara Falls
    By michael2480 in forum Trike Travel
    Last Post: 08-31-2014, 04:25 PM
  4. Hello from Great Falls, Va
    By skyegrl in forum New Member Introductions
    Last Post: 09-25-2013, 11:17 AM
