Likes Likes:  7
Results 1 to 20 of 20
Thread: Just Installed Love Jugs Mighty-Mites on 2015 Freewheeler
    80+ Posts
    Cochise, AZ USA
    Default Just Installed Love Jugs Mighty-Mites on 2015 Freewheeler
    The Mighty-mites went on fairly easy except for the supplied stainless washer that goes under the castle nut to hold the Mites on! It was too small to fit over the threaded end of the vibration dampner and I had to drill the hole larger!
    All went well with only one knuckle bust removing the old dampner! Plugged the 8 pin adapter on and plugged it into the Left side cover 8 pin power source and Shazzam the fans came on! Problem is the ignition wasn't on and key fob was in the house and trike is in the barn?
    Yep! That 8 pin connector isn't switched! So the fans can be turned on any time by anyone? Might as well wire direct to the battery with the supplied fuse block!
    I guess I was wrong in thinking it was switched. The nice 8 pin adapter makes hook up easy and no wire cutting; But???
    150+ Posts
    Jun 2015
    Yorktown, VA
    That's not right. Make sure you didn't plug in to the data link connector. I think the owners manual miss identified the two connectors. Data link is dark grey
    80+ Posts
    Cochise, AZ USA
    Quote Originally Posted by 52edub View Post
    It's the only 8 pin connector under Left side cover and it color matches the 8 pin adapter. It is light gray and Identified as Accessory plug in my manual!?
    The darker one under it is a darker almost black 6 pin non matching plug in. There are no other 8 pin grey connectors I can find This one was plugged with rubber plug! Just under the 50 amp fuse!
    150+ Posts
    Jun 2015
    Yorktown, VA
    That's the one, but it should shut anything plug in to it when the ignition is off and not work with the ignition off. Something is amiss.
    80+ Posts
    Cochise, AZ USA
    Nope Full time hot Ignition off! No key fob anywhere near the trike!
    It must be wired wrong Factory???
    150+ Posts
    Jun 2015
    Yorktown, VA
    Makes me think one of the wires is plug in wrong in the socket leaving it hot when the ignition is off. Do you have the electrical manual?
    80+ Posts
    Cochise, AZ USA
    No I don't have any of the manuals! But she' under warranty till 7-10-17
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    I have found that some factory HD accessory plugs are switched and some are hot all the time depending on the year and model.
    80+ Posts
    Cochise, AZ USA
    Mine is a 2015 freewheeler. I metered the harley deutch plug and the red with blue stripe is always hot. There'e a black ground wire directly above it on the plug; next to the black wire is a blue wire (may have a red stripe??) this is 12v switched on off with ignition!
    Not sure what it's for I don't have the electrical service manuals? So wouldn't that wire work as an on off source? Just move the pin in the adapter wire!?? I can't be the only one with this problem???
    Everyone I talk to says my plug should be switched? Well it is to the blue wire but not the red power wire?
    The fans look great and you can't hear them with the trike running! I havn't ridden it yet, trying to get the wiring right.
    150+ Posts
    Jun 2015
    Yorktown, VA
    Here is pictures of accessory plug under left cover.
    top of plug
    bottom of plug
    150+ Posts
    Jun 2015
    Yorktown, VA
    plug from Love Jugs
    Hope the pics help you figure out why your accessory plug is hot all the time.
    80+ Posts
    Cochise, AZ USA
    top of plug
    bottom of plug
    That's The plug all right Exact colors! My red with blue stripe is Hot all the time! Fans won't turn off and on with Ignition switch!
    Anyone else have this problem on their Accessory Plug???? Mine is 2015 Freewheeler.
    Dave
    80+ Posts
    Cochise, AZ USA
    Default 2015 Freewheeler Fans Update
    2015 Freewheeler Update; Just a quick fix: Use the black and purple wires: That purple/blue stripe next to the black ground is the switched 12V wire in your 8 pin plug
    top of plug
    That red wire/blue stripe Is 12V hot all the time in your 8 pin plug
    bottom of plug
    The 8 pin adapter plug that came with my Love Juggs Mighty-Mites was wired for non switched full time power! Just switch your red wire in the provided 8 pin plug up to the purple/blue hole next to the black ground and you now have a switched accessory power source to your fans!
    Simple fix
    The Harley Tech was right on it; 60 seconds with the little tool and wire was moved up!
    Thanks for all the help 52edub
    100+ Posts Red59's Avatar
    Apr 2014
    Walled Lake, MI US
    Quote Originally Posted by firebikerd View Post
    Simple fix
    So how do you like those Mighty Mites? Thinking about ordering some.
    150+ Posts
    Jun 2015
    Yorktown, VA
    Don't wait, get them. Was up on the Blue Ridge Parkway all weekend for Merging Mountains HOG rally. Great weather and perfect temperatures. However, going home the temps were in the mid-90s and the bike never went in to heat mode when I hit a little bit of traffic here and there. Perfect for city riding here in hot Virginia.
    80+ Posts
    Cochise, AZ USA
    Default Awesome!
    Quote Originally Posted by Red59 View Post
    I Concur with52edub! Buy them they work! When the Harley tech switched the pins on the adapter; he remarked "They really flow some air!"
    They have a high pitch turbo like sound without engine running but engine noise drowns it out! The black version is hardly noticeable and mine don't seem to shake much at all!
    It's gonna be close to or at 100deg here this week! 110deg in Tucson!
    I have the DK outlaw 606 air cleaner too! No hot oily gas's in the intake and a noticeable power boost!
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    I can relocate the pins on the 8 pin adapter plugs to switched rather than hot all the time so you wont have to fool with swapping the pins. I am making up a batch for stock that can be ordered individually or with your fan order.
    Just order item ADP-2 switched 8 pin adapter as seen HERE.
    Visit the BuyLoveJugs store HERE. Place an order and get a TT members bonus deal.
    Apr 2014
    Walled Lake, MI US
    Ordered some today from Papa Zook. Thanks for the feedback guy's.
    Red
  19. #19
    Apr 2014
    Walled Lake, MI US
    Ordered some today. Thanks for the feedback guy's.
    Red
    Received the Mighty Mites Yesterday (Thanks for the fast service Zook), installed them yesterday evening and went for a test ride.
    80 degrees when I left and 77 degrees when I returned, back road route no highway miles yet. With fans off I was getting temps around 265 degrees turned fans on the temp dropped down to 250 (temps from Power Vision display).
    So they did help some but from reading various reviews / comments I was expecting more than a 15 degree difference. Maybe it's to early to tell how much they really help until I put on some more miles with them.
    Red
  20. #20
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Red
    Hey Mitch,
    Thanks much for the order. In 80 degree ambient temp, 250 CHT is a good number and unless it is really cold out, as in 30s to 40s, you wont see it get much below that number during normal operation, nor do you want it much lower as that is where it needs to be to burn off any moisture and acid contaminates that naturally accumulate in the crankcase.
    ET, aka CHT is read off the front cylinder and not the rear cylinder which runs much hotter and is where the damage is often done if not kept in check. This is why Harley now offers a new cooling fan mounted behind the rear cylinder to direct that heat down and away from the rider and passenger. They know engine heat is a serious problem.
    You can bet that Harley, LeNale and Jim's Fans would be selling a dual fan system if Love Jugs didnt have a utility patent on it because it has been proven to be the most effective method out there for cooling the front and rear cylinders, by directing air directly at the hottest spot, the spark plug, rather than between the cylinders.
  1. Replies: 25
    Last Post: 09-08-2019, 04:06 PM
  2. About to install Mighty Mites
    By Fearless in forum Harley Tri Glide
    Last Post: 04-09-2017, 09:18 PM
