Likes Likes:  48
Page 6 of 6 FirstFirst 1 2 3 4 5 6
Results 101 to 104 of 104
Thread: Engine Date
  1. #101
    Apr 2015
    Batesville, AR. 72501
    SLIPPERY SLOPE WARNING
    VW engines can become bottomless money pits real quick!
    Don't forget that your original project was to get the trike running and see how it ran. I'd say get the needed parts as identified so far, put it together, and ride it around some and see how it does. Don't plan any long trips! Just putt around town till you know better what you've got.
    If you have a trailer that it will fit on, great. (Plan B "Breakdown" for recovery.) If not, if you have a vehicle with a trailer hitch, you can cobble up a front wheel carrier to get it home Google will help you with ideas.
    If you haven't ridden a trike, ride it a while before you start sinking $$$ into it.
    Just my .02
  2. #102
    60+ Posts
    May 2017
    San Angelo TX USA
    Quote Originally Posted by vwbug72501 View Post
    Just my .02
    HAHAHAHA
    Yes the plan for now is to get it running with just the stuff that is the bare minimum, I just want to make sure i'm getting the correct parts for the engine and transmission that i have now.
    Chances are I will end up saving my pennies and buy a crate engine for it and having the transmission rebuilt at some point.
  3. #103
    80+ Posts Gator Monroe's Avatar
    Aug 2017
    Oak Run Ca. USA
    Just my .02
    Rookie Gator sees this reply too late in the Game ...
  4. #104
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Money pit configuration....
Tags for this Thread
