Likes Likes:  5
Results 1 to 11 of 11
Thread: Oil Change
    Apr 2013
    Boulder, Utah
    Default Oil Change
    Ok this may be a silly question but how do you do your own oil change on a trike? It is so low to the ground you can't get anything under it. If you jack up the front end then the trike is not level. How do you do it?
    200+ Posts knob's Avatar
    Jan 2015
    Metropolis
    You can drive it up on some ramps or 2x's.
    450+ Posts GrandpaDave's Avatar
    Jul 2013
    Hankinson, ND, USA
    Here's a picture of how I run mine up on ramps and it works great.
    Apr 2013
    Boulder, Utah
    That is a great idea right there. How do you keep the boards from slipping down on the ramps?
    Quote Originally Posted by GrandpaDave View Post
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Quote Originally Posted by dheaton View Post
    You might want to address why yours is so low.
    Jul 2013
    Hankinson, ND, USA
    The boards have an aluminum ramp bracket on them that I position over the lip on the metal ramps and that keeps them from sliding down. You can see the aluminum bracket on the ramp behind the front wheel.
    May 2011
    San Angelo
    Now that is what I call "Using What's Available" !!!
    2015 GL1800/Roadsmith HTS1800
    100+ Posts
    Jun 2017
    Moville, IOWA
    Put a small scissor floor jack under the motor. Jacket up a ways to allow you to get a low profile oil pan under it remove drain plug filter let the scissor jack back down once your oil has completely drained out raise your floor jack back up plug-in new filter remove Jack fill motor with oil. Lot safer than trying to put a tricycle up on three car ramps
    300+ Posts paid4c4's Avatar
    Mar 2016
    Crestview Hills, KY, USA
    The aluminum ramp bracket's are available on Amazon.com for 16.99.
    Bill
    There was a post here awhile back. Guy made a kewl set up that you could ride up, then remove the middle portion to work on the trike. Also because the ramp was in sections, it stowed easily. I tried to find it, but couldn't.
    Maybe the op will repost it or a link.
    May 2011
    San Angelo
    I remember the big ramp/deck you are thinking of but can't find it either. I always though it was too awkard and bulky. Here is a pix of the ramps I've used for years... Several guys around the world have made them and like them.. PM me your email if you want more inforation and photos.
    Name:  All Ramps.jpg
  1. Oil Change using a Flo and Go Vacuum Oil Change Kit
    By daf62757 in forum Harley Tri Glide
    Last Post: 03-17-2017, 06:14 PM
  2. Oil Change
    By davek in forum Harley Tri Glide
    Last Post: 09-08-2016, 11:09 AM
