Likes Likes:  1
Results 1 to 3 of 3
Thread: Wet bolt for Voyager
    80+ Posts Oldveteran's Avatar
    Feb 2017
    Amarillo, Texas
    Default Wet bolt for Voyager
    "Wet" bolt for Voyager
    I have just spent the entire day surfing the internet trying to find the zerk fitted "wet" 1/2 in bolt that runs through the bushing on the suspension fork! They don't exist. Some company had to make them because I have two of them on my desk, and one is completely WORN out. I tried EVERY nut and bolt place I could locate, dream of, make up, or imagine! They are for naught! I was going to try some boat trailer spring leaf bolts and bushings. This is all well and good by they only come in 9/16" id and 3 inch length. My bolt is 1/2 inch and 2 1/4 inches long. In addition, the bushing is only 1.0 inch long. The shortest I could locate were 1.75 inches. Don't call Voyager.....they just don't respond and don't sell any parts!
    You can get a whole new fork assembly if you want, but there ain't no stinking PARTS ! I could drill out the forks from 1/2 to 9/16 and use a 9/16 wet bolt, but they are all still way too long. I could cut the 9/16 bolt off, have it re-threaded and cut the bushing to fit. $$$$$$. This is way too complicated, time consuming and expensive just to replace a bolt and a bushing. Any one have any suggestions?
    OLDVETERAN
    Let's ride folks 'cause sunshine makes me happy.
    300+ Posts dadztoy's Avatar
    Dec 2011
    Georgetown, Tennessee, USA
    I remembered my old Chicago Hardware Company - McMaster Carr... Hope this helps... They list one that is 2 13/16" - might work???
    https://www.mcmaster.com/#grease-bolts/=17zj2xs
    Les
    Feb 2017
    Amarillo, Texas
    Default WET bolt
    Quote Originally Posted by dadztoy View Post
    Les
    Thanks I'll giv them a try.
  1. Harley 4 bolt to GM 5 bolt adapter
    By TK8614 in forum Harley Freewheeler / Road Glide 3
    Last Post: 04-08-2016, 08:35 PM
  2. New Bolt-on Voyager triker in North Carolina
    By bokobob in forum New Member Introductions
    Last Post: 03-25-2014, 09:22 AM
