LD-Ordie3SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie3Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie3LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  3
Results 1 to 20 of 20
Thread: DNA trike axle rotors
    Jun 2017
    Elliott City Maryland USA
    Default DNA trike axle rotors
    Does anyone have any idea where to get the brake rotors for the DNA axle. What bike did they originally come off of?
    Welcome to Trike-Talk......From Sunny New Jersey....
    I'm Sure someone will chime on soon with the info you are looking for
    welcome aboard. I'm missing something in your question.
    30+ Posts
    Sep 2013
    Spanaway, Washington
    I think you can get them from DNA. They do have a website.
    30+ Posts
    Jan 2013
    Slidell, LA
    If you've worn out your rotors, you must have put a few miles on the axle. Just wondering how many, and your opinion of it's quality and durability?
    Bob
    Jun 2017
    Quote Originally Posted by bobscogin View Post
    Bob
    I have about 11,000 miles on the axle, had trouble at first with the axle nut coming loose on the left wheel (as you face the front of the bike) that did something to the splines on the hub cured it by swopping the hubs and making a castle nut from the existing nut with a cotter pin through it. The axle is chain run for ease of removing the chain.
    I am asking about the rotors because I was quoted $159.00 each by DNA and I think that is to much. So I am trying to find out what bike the rotors come off of to see if they are less expensive.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by Graham Banks View Post
    More than likely they are specific to DNA being manufactured in the Third World. The diameter is 9.25" and .250" thick. It will be hard to find a rotor that small for a motorcycle, probably scooter application. After machining to fit, the DNA price doesn't sound too bad. If you doubt my word, go to the Wilwood site and see what they get for their motorcycle rotors.
    Jim Murphy
    Iron Butt Rider 2001
    I agree with this answer
    Too many times manufacturers buy weird stock that others cannot get to put a lock on their buying power
    If Wildwood or Performance Machine aint got em u may be forced to go with DNA
    JMO
    30+ Posts
    Jan 2013
    Slidell, LA
    Sorry I can't help with your rotor inquiry, but I do appreciate you taking the time to let me know about your experience with the DNA axle.
    Bob
  11. #10
    Dec 2016
    westminster, co , adams
    Default Dna trike brake pads
    The pads are easy ordered through a go cart shop as this is what the calipers are from
    35 bucks a pair
  12. #11
    Jan 2018
    ONTARIO CANADA
    Default PADS
    Quote Originally Posted by peter wolfe View Post
    the pads are easy ordered through a go cart shop as this is what the calipers are from
    35 bucks a pair
    how can i get them.....do you have some names and numbers ?
  13. #12
    Jan 2018
    ONTARIO CANADA
    Default PADS
    Hi ...where can I get brake pads for my DNA trike kit other than DNA and what do I ask for ?thanks...Jeff
  14. #13
    Martinsburg, WV
    Quote Originally Posted by JEFFCURTIS View Post
    https://mjtrikes.com/shop/index.php?...roducts_id=388
    Jim Murphy
  15. #14
    Jan 2018
    ONTARIO CANADA
    Default pads
    THANK YOU
  16. #15
    Jul 2017
    Finland
    Default Pads
    Hi, if you have the two piston calipers they are Brembo copys so easy to find the pads. Check www.bankeperformance.com to see what the Brembos look and they have pair of pads $22 for one caliber and for different thick discs. The rotors might be of 2003 Piaggio Nexus 500 scooter, that I'm not 100% shore but you might check them.
  17. DKCustoms postbit
  18. #16
    Jan 2018
    ONTARIO CANADA
    Quote Originally Posted by skipi56 View Post
    hi, if you have the two piston calipers they are brembo copys so easy to find the pads. Check www.bankeperformance.com to see what the brembos look and they have pair of pads $22 for one caliber and for different thick discs. The rotors might be of 2003 piaggio nexus 500 scooter, that i'm not 100% shore but you might check them.
    thank you...have e-mailed them
  19. #17
    Jul 2017
    Finland
    Unhappy Disc
    Just got checking the discs, not the Nexus Search goes on.
  20. #18
    Martinsburg, WV
    Jeff, I have them but I can't give you a shipping amount until I get to the Post Office with the package.
    I shouldn't think it would be more than $16.00 anyways.
    UPS would be outrageous.
    I found them in Europe, seems they are popular over there.
    Jim Murphy
  21. #19
    Jan 2018
    ONTARIO CANADA
    Thanks Jim...let me know when and where...got nowhere with bankeperformance.com
  22. #20
    Martinsburg, WV
    I sent an email with my phone number, call me in the morning.
    Jim Murphy
  1. Hi All, Still undecided on trike axle
    By Reb in forum New Member Introductions
    Last Post: 09-28-2019, 11:51 AM
  2. Honda GL1800 with lehman trike rear rotors
    By warren in forum Lehman Trike
    Last Post: 02-18-2017, 09:42 AM
  3. Solid Axle vs Independent Axle
    By vbbuilt in forum Harley Trike Conversions
    Last Post: 09-15-2014, 11:53 AM
  4. Trike axle help
    By isalgue in forum General Discussion
    Last Post: 07-18-2011, 04:35 PM
