Results 1 to 7 of 7
Thread: GPS Control Panel
    20+ Posts
    Jun 2012
    Horseshoe Bend, ar,usa
    Default GPS Control Panel
    I never use the gps on my 2006 goldwing motor trike. What effect will removing this control panel and replacing for another function have on the operation of the electronics. Thanks for any input. exphoneman
    May 2011
    San Angelo
    I strongly suspect the map function would be disabled completely as it would probably shut the NAVI operation down. Keep in mind also that your onboard clock function is integrated into the GPS so you would also loose that.
    2015 GL1800/Roadsmith HTS1800
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Like Gold Rush said, the clock and of coarse the GPS. To know for sure, disconnect it's control panel plug and see all that happens.
    20+ Posts
    Jun 2012
    I unplugged the control panel today. Clock still works. Don't use the maps part. All other functions appear to work. More info later.
    Thanks/Exphoneman
    May 2011
    San Angelo
    Quote Originally Posted by exphoneman View Post
    Thanks/Exphoneman
    I'm surprised the clock still functions at all Bud since you have to go through the GPS control panel to set/adjust time settings. Interesting.......
    JustWings.com
    May 2016
    I've read before about taking control over GPS's LED screen by making it show a smart phone's screen. Basically, whatever is on the phones screen is on the LED screen.
    However, it seems much easier to get a RAM mount and mount the Smart Phone then to go through all that trouble.
    20+ Posts
    Jun 2012
    Default Gps control panel
    Gps still has power. Fuse 31 per the repair manual.
  1. Side Panel Studs?
    By kam582 in forum Honda Trikes
    Last Post: 02-22-2017, 05:12 AM
  2. Replacement panel for the level headlight/memo panel
    By paid4c4 in forum Honda Trikes
    Last Post: 05-26-2016, 10:20 AM
  3. Chrome Side Panel Covers
    By Tigercat in forum Stallion Trikes
    Last Post: 08-10-2015, 02:30 PM
  4. Bulging Left side panel
    By HoppR in forum Harley Freewheeler / Road Glide 3
    Last Post: 02-13-2015, 03:11 PM
  5. J&M 2003 CB Audio and Aux Fuse Panel
    By Yogisan in forum Accessories
    Last Post: 05-04-2011, 08:23 AM
