Likes Likes:  18
Thanks Thanks:  2
Results 1 to 15 of 15
Thread: Harley trouble codes
    Default Harley trouble codes
    Harley Trouble Codes
    The following procedure will instruct in retrieving and clearing ECM Diagnostic Trouble Codes and TSM/TSSM codes through the Harley guage cluster as well as a list of codes.
    1- Turn Ignition switchto OFF & Run/Stop switch is to Run.
    2- Push odometer resetbutton in & hold.
    3- Turnignition switchto Ignition and release the odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
    4 - Push the odometer resetbutton once and you will seethe selection menu "PSSPt" with the first P flashing.
    5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer resetbutton one time. (from P to S to SP to t and back to P, etc.)
    P = ECM/ICM(Electronic Control Module)[EFI] /Ignition Control Module[Carbureted])
    S = TSM/TSSM (Turn Signal/ Security Module)
    SP = speedometer
    T = tachometer
    6 - To get the DTC within an area of diagnostics, push and hold the odometer resetbutton in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer resetbutton again to view additional codes if they exist.
    7 - Record the codes.
    8 - If DTC's are not to be cleared, Press and release the odometer resetbutton. Part number of module will be displayed.
    NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
    9 - Press and release the odometer reset button to continue to the next module.
    10 - Turn Ignition switch to OFF.
    On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
    "No Rsp" (no response) will also appear if the run/off switch is in the off position when doing this procedure.
    HFSM = Hands Free Security Module
    TSM = Turn signalmodule
    DTC’s are designated by a P,C,B or U
    P codes indicate issues monitored by ECM
    C codes indicate an issue with ABS
    B codes are set by Radio, Instruments and BCM
    U codes indicate a communication problems with the modules
    Fault Code Abbreviation List
    ABS – Anti-Lock Braking System
    ACR – Automatic Compression Release
    AFR – Air Fuel Ratio
    AIS – Active Intake Solenoid
    ATS – Air Temperature Sensor
    BAS – Bank Angle Sensor
    BCM – Body Control Module
    CAN – Controller Area Network
    CCM – Cruise Control Module
    CKP – Crank Position Sensor
    DLC – Datalink Connector
    DTC – Diagnostic Trouble Codes
    ECM – Electronic Control Module
    ECT – Engine Coolant Temperature
    ECU – Electronic Control Unit
    EFI – Electronic Fuel Injection
    EFP – Electronic Fuel Pump
    ET – Engine Temperature sensor
    FI – Fuel Injectors
    FPR – Fuel Pressure regulator
    H-DSSS – Harley-Davidson Smart Security System
    HCU – Hydraulic Control Unit, ABS
    [/stag_one_half][stag_one_half_last] HFSM – Hands Free Security Module
    HO2S – Heated Oxygen Sensor
    IAC – Idle Air Control actuator
    IAT – Intake Air Temperature sensor
    ICM – Ignition Control Module
    IMAP – MAP + IAT in one unit
    ISS – Ion Sensing System
    JSS – Jiffy Stand Sensor
    LHCM – Left Hand Control Module
    MAP – Manifold Absolute Pressure Sensor
    MHR – Right Hand Control Module
    RCM – Reverse Control Module
    TCA – Throttle Control Actuator
    TGS – Twist Grip Sensor
    TMAP – Intake Air Temperature / Manifold Absolute Pressure equipment
    TPS – Throttle Position Sensor
    TSM / TSSM – (Turn Signal / Turn Signal Security Module)
    VE – Volume Efficiency
    VIN – Vehicle identification number
    VSS – Vehicle Speed ​​Sensor
    WSS – Wheel Speed ​​Sensor
    P0031 Front HO2S low/open
    P0032 Front HO2S shorted/high
    P0051 Rear HO2S low/open
    P0052 Rear HO2S shorted/high
    P0072 AAT sensor low
    P0073 AAT sensor high/open
    P0107 MAP sensor failed low/open
    P0107 Map Sensor Open/Low
    P0108 MAP sensor failed high/open port
    P0112 IAT Voltage Low
    P0113 IAT Voltage Open/High
    P0117 ET Sensor Low
    P0118 ET Sensor High
    P0120 TPS1 Range Error
    P0122 TPS1 Low
    P0123 TPS2 High/Open
    P0131 Front Oxygen Sensor Low / Engine Lean
    P0132 Front Oxygen Sensor High / Engine Rich
    P0134 Front Oxygen Sensor Inactive
    P0151 Rear Oxygen Sensor Low / Engine Lean
    P0152 Rear Oxygen Sensor High / Engine Rich
    P0154 Rear Oxygen Sensor Inactive
    P0220 TPS2 Range Error
    P0222 TPS2 Low/Open
    P0223 TPS2 High/Open
    P0261 Front Injector Open/Low
    P0262 Front Injector High
    P0263 Rear Injector Open/Low
    P0264 Rear Injector High
    P0265 Rear injector shorted high
    P0371 CKP sensor wrong number of pulses
    P0373 CKP Sensor Intermittent
    P0374 CKP Sensor Synch Error
    P0444 Purge Solenoid Open/Low
    P0445 Purge Solenoid High
    P0501 VSS Sensor Low
    P0502 VSS Sensor High/Open
    P0503 VSS failed high
    P0505 Idle speed control unstable
    P0562 Battery/ECM Voltage Low
    P0563 Battery/ECM Voltage High
    P0572 Brake Switch Low
    P0577 Cruise Control Input High
    P0603 ECM EEPROM Memory Error
    P0605 ECM FLASH Memory Error
    P0641 5 Volt Reference 1 Out of Range
    P0651 5 Volt Reference 2 Out of Range
    P0691 Fan/cooling relay output low/open
    P0692 Fan/cooling relay output high
    P1001 System Relay Coil Open/Low
    P1002 System Relay Coil High/Shorted
    P1003 System relay contacts open
    P1004 System Relay Contacts Closed
    P1009 VTD Disabled Fuel Due to Incorrect Password
    P1010 Missing Password
    P1017 ET indicates overheating
    P1019 ECT Difference (high temp)
    P1270 TGS 2 A/D Validation Error
    P1351 Front Ignition Coil Driver Open/Low
    P1352 Front Ignition Coil Driver High/Shorted
    P1353 Front Cylnder No Combustion
    P1354 Rear Ignition Coil Driver Open/Low
    P1355 Rear Ignition Coil Driver High/Shorted
    P1356 Rear Cylinder No Combustion
    P1357 Front Cylinder Combustion Intermittent
    P1358 Rear Cylinder Combustion Intermittent
    P1475 Exhaust Actuation Position Error
    P1477 Exhaust Actuator Open/Low
    P1478 Exhaust Actuator Shorted/High
    P1501 Jiffy Stand Sensor Low
    P1502 Jiffy Stand Sensor High
    P1510 EFI Limited Performance Mode
    P1511 EFI Power Management Mode
    P1512 EFI Forced Idle Mode
    P1514 ETC Air Flow Fault/Error
    P1600 EFI Module Processor Internal Error / Watchdog Error
    P1608 Loss of continuous battery
    P1655 ACR solenoid low/open
    P1656 ACR solenoid shorted high
    P1691 Cooling fan left low/open
    P1692 Cooling fan left shorted high
    P1693 Cooling fan right low/open
    P1694 Cooling fan right shorted high
    P2100 EFI Motor Circuit Open
    P2101 EFI Motor Circuit Range Performance (Actuation Error)
    P2102 EFI Motor Circuit Low
    P2103 EFI Motor Circuit High
    P2105 EFI Forced engine shutdown
    P2107 EFI Module Processor Internal Fault
    P2119 EFI Motor Throttle Body RangePerformance
    P2122 TGS1 Low/Open
    P2123 TGS1 High
    P2127 TGS2 Low/Open
    P2128 TGS2 High
    P2135 TPS Correlation Error
    P2138 TGS Correlation Error (Twist grip sensor)
    P2176 EFI Closed Position Not Learned
    P2184 ECT sensor low
    P2185 ECT sensor high
    P2300 Ignition coil driver low/open (front)
    P2301 Ignition coil driver shorted high (front)
    P2303 Ignition coil driver low/open (rear)
    P2304 Ignition coil driver shorted high (rear)
    I have lots more saved on my hard drive, stay tuned and I will post them
    Sep 2014
    Box Elder, SD
    Thanks. Way to many things to go wrong. Jim
    2250+ Posts
    Ocala, Florida
    Thanks Jack. Very nice addition to my "Tech Tips" folder that goes with the bike when it's passed on to my son.
    PC
    Beware of liberals posing as Americans.
    100+ Posts wingit's Avatar
    Jul 2015
    Richmond Mn.
    Default Only 3
    On my RK evo it was stage one two three
    Quote Originally Posted by wingit View Post
    Bet it hauled the mail real good
    300+ Posts
    Mar 2018
    Waelder, Texas
    Default Need help with diagnostics
    This may not be the place to ask, but I need help. This issue is not about my Freewheeler rather a good friends bike. (2008 Street Glide) In the past year, his check engine light has come on a couple of times with no other issues. Then recently, soon after a grip change it went into limp mode. We looked at the infamous green connector (for the TGS) in the handlebars and it looks fine, that is, not broken or disconnected. Now it's running fine again. Here's the problem. When we try to check for codes, we get P = no response, S = none, SP = none, T = none and b = no response. I believe the "b" is for anti-lock brakes which he doesn't have. Why do we get "P" = no response? The handlebar switch is "on". This bike has a Power Commander if that matters. Thanks for any ideas.
    Quote Originally Posted by RKplus10 View Post
    Strange with no response
    The B is strange, I thought B is BCM?
    Is The Power Commander capable of codes like the PV Tuner?
    300+ Posts
    Mar 2018
    Waelder, Texas
    Thanks Jack, but this b seems to be an area of the diagnostics, not a DTC. The menu comes up as PSSPtb . The first area P and the last area b show "no response". The other three show "none". I'm really not familiar with the Power Commander either, but I don't think it's that advanced. Maybe it could be keeping the P from giving us the diagnostic view of the ECM?
    If the PC is plug and play I would un hook it and try a scan
    300+ Posts
    Mar 2018
    Waelder, Texas
    OK, I'm going to suggest that to my buddy and let him decide what to do next. I'll report back if I have anything new to add. Thanks again.
    May 2020
    Albrightsville,Pa,USA
    Question Looking for Help
    It's a 2010 Harley 103cid and I'm getting code P1010/missing password?
    100+ Posts Cagmo's Avatar
    Jun 2016
    Glen Carbon, IL, USA
    Default DTC b2121 BCM malfuncti0on
    I had a steady red check engine light on my '16 TG that popped up out of the blue. No maintenance lately or anything other than riding and wiping down. I followed Jack Klarich's advice to run through the DTC's and clear out the code, which turned out the light. 300 miles later still no problems. Thank you for your help, sir.
    Default Waiting out the last of the Rain Today
    I should be able to get in a good ride today after 3, the rain is about to end here
  1. Fault codes
    By Bagger in forum Harley Trike Conversions
    Last Post: 05-30-2020, 03:16 PM
  2. paint codes
    By retiredalaskan in forum Honda Trikes
    Last Post: 09-20-2012, 05:19 PM
  3. Diagnostic Codes
    By Paw Paw Willie in forum Harley Trike Conversions
    Last Post: 04-05-2012, 06:58 AM
  4. color codes
    By ODDOMAN in forum Stallion Trikes
    Last Post: 11-26-2010, 09:10 PM
