Likes Likes:  3
Results 1 to 20 of 23
Thread: Rear Shock
    Jun 2017
    New Chicago , In. USA
    Default Rear Shock
    Has anyone tried to use a stand alone shock without the airbag setup? 2014 RT. I cannot get a decent ride on this machine no matter where the air pressure is (40 _65 psi ) It seems like the airbag only is doing the suspension. 24 K on the machine. Nothing but rough roads in Northern Indiana also..... It has always been a rough ride, maybe the shock ( whatever it doe's) has never been anygood..
    Welcome Jack 'To Trike-Talk.... If you think your roads are rough, Just take a ride out my way in New Jersey, Some of our pot holes are deep enough to lose Jimmy Hoffa in........Wish i could help you i gave up my Spyder a few years ago, But I'm sure someone will come on with the help you need...Agin ...Welcome...
    Jun 2017
    Default rough roads
    Yes the roads are bad. I came across a smooth secton and almost lost control. Soon they will all be toll roads and one will pay for the holes we drive in.......
    Oct 2010
    USA
    what do you mean by decent ride?
    What air pressure are your tires set at?
    Are you sure the compressor is working and not leaking air too?
    Jun 2017
    Default Rear Shock
    Do not have a compressor, and I have no leaks, tried pressure from 45-70 and stil have a harsh ride. Tires are, 28 rear and 20 fronts. Thanks
    Oct 2010
    USA
    Quote Originally Posted by manxnorton View Post
    Ok now I am confused. You have a 2014 RT Spyder with no air compressor that is mounted on the bike for the rear shock??
    Bob's Curmudgeon Apprentice
    consitter's Avatar
    Jun 2015
    Ashland, KY
    Your bike's compressor that airs up the shock is what he means. All Spyder RTs have them on board.
    Jun 2017
    Default compresser
    Thats right, I have a stock RT and the air is adjusted manually.....
    consitter's Avatar
    Jun 2015
    Ashland, KY
    How is it that yours doesn't??
    Oct 2010
    USA
    OK lets try this.
    You adjust your rear shock with a shock pump by hand and have disconnected the on board air compressor?
    Jun 2017
    Default Shock
    Quote Originally Posted by consitter View Post
    My Spyder is the very stock RT, Air is adjusted under the seat with Schrader valve. My spyder has no extras, it is a plain machine. The dealer I got it from says he cannot give away this model as it is so plain. It is a 2014 RT SE6........
    Oct 2010
    USA
    Well I have a 2014 Rt and have a air compressor. I wasn't aware the Rt was made without one. I know the Rts has a few less chrome things but the compressor is still t there
    Oct 2010
    USA
    Do you use a hand pump ? Does the rear raise and lower when you put air in or take out
    800+ Posts Big Juice's Avatar
    Nov 2013
    Hot Springs Village, Arkansas USA
    My dealer told me to use 24 in rear and 18 in front, on my F3 Limited. Not what the book calls for, but his recommendation. Being an F3, it rides a little rougher than an RT anyway, I think. My wife's says her RT rides smooth at 28 rear, 15 front. Good luck and keep adjusting until you get what works for you!
    ​O J Miles - now riding "Lucille", a 2017 Spyder F3-Ltd. Roadster.
    When 2 wheels aren't enough and 4 are too many.
    Ahhhh, a hot cup of coffee and a good cigar, after a good ride.......
    Oct 2010
    USA
    since I found out a basis RT does not have a compressor. Like above stated adjust till you are comfortable.
    But also does the rear raise up and down when you put in air. And how are you putting in air with what type of device??
    Jun 2017
    Default shock
    OK lets try this.
    Never had a pump, plain jane RT's the air is done manually under the seat with the schrader valve. Still would like to know just what the shock doe's which in my case is not much......
    Oct 2010
    USA
    It's should stiffen up or soften the ride over bumpy retain when used with air. You want a better shock Ella has then but pricey. They set it up to your weight and how you ride
    Jun 2017
    Default Shock
    Yes, it goe's up and down when air added, use a compressor carefully to get desired psi. I can push down on the passenger handles about four inches, and that goes away when we get on. No matter where the psi is (45-65) it has always been that way so it is hard to tell if the shock is doing anything. Combined weight on the machine is less then #300 lbs..
  19. #19
    Jun 2017
    Default Shock
    OK lets try this.
    There never was a compressor on this model RT SE6 it is a basic RT. Adjust air under the seat via Schrader valve.
  20. #20
    consitter's Avatar
    Jun 2015
    Ashland, KY
    I'm guessing you've tried an old fashioned bicycle pump then...you could definitely 'fine tune' it much easier that way.
    I don't know...I'm at the end of a 10 hour shift, so I'm not thinking straight.
  1. Broken rear shock
    By pcombe in forum General Harley Chat
    Last Post: 06-14-2019, 08:27 PM
  2. Tr-Glide rear shock options with shock lift mount.
    By rick1201 in forum Harley Tri Glide
    Last Post: 02-12-2016, 01:50 AM
  3. Rear Shock
    By rgc in forum Harley Trike Conversions
    Last Post: 09-06-2012, 10:09 AM
  4. Tri-Glide rear shock psi
    By motorman7 in forum Harley Tri Glide
    Last Post: 09-01-2009, 09:54 PM
