Results 1 to 10 of 10
Thread: left turn indicator burning very dim in slight rain storm or washing
    20+ Posts BVG123's Avatar
    Aug 2016
    Morrilton
    Default left turn indicator burning very dim in slight rain storm or washing
    93 gold wing that i have change all the lights to leds .now has a sight dim indicator burning when it slightly rains or if i wash it . does not last very long . drys out and quits . any suggestions were to start looking.
    Jun 2008
    Lovington, NM, U.S.A.
    Front or rear lights?
    Water could be getting into the connector.
    Retired trike builder
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Clean it's contacts and seal the area from water getting in.
    Aug 2016
    Morrilton
    Quote Originally Posted by trike lady View Post
    just the indicator not the lights. can"t see water getting in to the indicator connector with just enough rain just to dampen the windshield. thanks for you help
    Aug 2016
    Morrilton
    Quote Originally Posted by GoldWingrGreg View Post
    which connector would you look at first. thanks for you help
    JustWings.com
    May 2016
    Quote Originally Posted by BVG123 View Post
    Sorry ... meant the connection points at the dim bulb's socket. Assuming there is 12v+ at the socket, in an incandescent bulb circuit, dim means there is a problem with the ground. However, it could be a ground problem in that circuit elsewhere.
    Jun 2008
    This is behind the meter panel that plugs into the harness.
    Circled in red is the connector. The connectors circled in blue go to the LCD display (unless you have an Interstate).
    There could be a small chafe in the sub-harness wire that the slightest bit of moisture allows the indicator to glow faintly.
    Also check the connection where you installed the LED load equalizer.
    Also do you have a service manual to show you the steps in disassembly?
    The attached video will give you an idea of what is involved in getting to the meter panel, even though the video maker is dealing with speakers.
    Aug 2016
    Morrilton
    Sorry ... meant the connection points at the dim bulb's socket. Assuming there is 12v+ at the socket, in an incandescent bulb circuit, dim means there is a problem with the ground. However, it could be a ground problem in that circuit elsewhere.[/QUOTE]all lights have been changed to leds no incandescent bulbs. including the instrument panel. did not start until i changed to leds no load resisters as it has a electronic flasher for leds.
    Aug 2016
    Morrilton
    yes i have a service manual. i will check these connectors again i clean these when i installed the leds and add dialectic grease to them thanks again
    JustWings.com
    May 2016
    Since it's an LED circuit, verify that all the little LED's are working on the bulb, and that the voltage to the bulb is the same as others in the same circuit.
  1. Turn Signal Indicator Lights
    Last Post: 05-15-2015, 05:14 PM
  2. Been running the new trike a bit. and a slight problem..
    By classicfins in forum VW Powered Trikes
    Last Post: 07-24-2012, 09:41 PM
  3. Front end noise on left turn
    By ratdaddy in forum Harley Trike Conversions
    Last Post: 07-01-2011, 03:23 PM
  4. Emergency Brake Indicator Burning Constantly
    By FrancesLipscomb in forum Stallion Trikes
    Last Post: 12-02-2008, 06:26 AM
