Likes Likes:  1
Results 1 to 4 of 4
Thread: Brake Squeal
    Jul 2017
    Beverly Hills, FL
    Default Brake Squeal
    Have an "08" GL1800 with a Lehman/Manarch II coversion. I recently replaced rear brakes because they squealed real bad. Put new EBC # FA314R brake pads, had both disc rotors machined, and used a Permatex product Disc Brake Quiet on the back of all four pads. This is a spray that is suppose to quiet disc brakes. For the first ten miles everything good. Went for ride the next day, and yes you guessed right, squeal is back. If anyone has experienced this behavior with there trike, please advise. Thanks for any advice.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    You should have used the fa314sv instead of the fa314r.
    You should chamfer the upper edge of the pad too so it does not over ride the rotor.
    Did you have the honda brake recall done ? If not, your brakes might be dragging.
    Jim Murphy
    Iron Butt Rider 2001
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Try cleaning the pads and rotors with BrakeClean. I always use the red can.
    100+ Posts RUMRUNR's Avatar
    Basehor, Kansas, USA
    What he said chamfer the leading edge of the pad also.
  1. Replies: 2
    Last Post: 02-03-2017, 12:27 PM
  2. Brake Squeal ???
    By sandrooney in forum Harley Tri Glide
    Last Post: 11-10-2014, 07:10 AM
  3. Loud Squeal
    By lboos in forum Harley Trike Conversions
    Last Post: 03-21-2014, 01:20 PM
  4. Belt Squeal
    By Razorback Trike Rider in forum Harley Trike Conversions
    Last Post: 04-24-2010, 07:56 AM
  5. Experiencing rear brake squeal???
    By azbob09 in forum Harley Trike Conversions
    Last Post: 03-20-2010, 01:27 AM
