Results 1 to 2 of 2
Thread: Adjustment for trigg
    Jul 2017
    Glenwood, Newfondland, Canada
    Default Adjustment for trigg
    Tryng to set up trigg kit for bros dad.
    Anyone help with how to set knuckles.
    How much down pressure on outriger?
    What are symptoms of too much not enough pressure?
    200+ Posts
    Nov 2010
    CALHAN COL.
    Default Some help
    Quote Originally Posted by Dlmahan View Post
    Tring to set up trigg kit for bros dad. Anyone help with how to set knuckles. How much down pressure on outriger? What are symptoms of too much not enough pressure?
    Its not too hard #1 you put the rear tires of kit up on a 1 inch board and then set knuckles so there is no weight on them' Turn knuckles 3/4 turn down and set Now ride it if that is too much the rear tire well spin under take off , just keep playing with the down force until you get it set right. Rear tire should not spin under normal take offs. BIG DENNY
  1. Trigg Kit
    By BIG DENNY in forum Outrigger Style Trikes
    Last Post: 12-02-2016, 07:30 PM
  2. Trigg
    By Dude in forum Outrigger Style Trikes
    Last Post: 10-16-2016, 10:35 PM
  3. Trigg
    Last Post: 10-08-2014, 01:13 PM
  4. Trigg kit
    By BIG DENNY in forum General Discussion
    Last Post: 08-19-2014, 11:44 AM
  5. new trigg trike
    By billie in forum Honda Trikes
    Last Post: 01-13-2013, 12:46 AM
