Results 1 to 7 of 7
Thread: DNA rear axle question.
    30+ Posts
    Jan 2013
    Slidell, LA
    Default DNA rear axle question.
    There are probably some here who have built a trike from scratch and used a DNA rear end/axle. I'm trying to find out how far the sprocket centerline is offset from the centerline of the axle? Anyone know?
    Bob
    May 2017
    Quincy, Fl
    Mine measures 4.25".
    30+ Posts
    Jan 2013
    Slidell, LA
    Quote Originally Posted by brattrike View Post
    Thanks, brattrike. I'm given to understand that the sprocket offset on the DNA axle is correct for Harleys, but not sure which models the 4.25" would correlate to.
    Bob
    May 2017
    Quincy, Fl
    From the DNA catalog, it looks like they have 5 different axles.
    I have the M-AX-2006 model on my '91 Sportster 883 Hugger.
    Hope this helps.
    80+ Posts dmillsr3's Avatar
    Jun 2016
    Double Oak, TX, USA
    Quote Originally Posted by bobscogin View Post
    Bob
    What bike do you have?
    Shade Tree Conversion
    30+ Posts
    Jan 2013
    Slidell, LA
    Hope this helps.
    Thanks. I've looked at the catalog and I think the different models seem to arise from whether they are chain or belt, and 2 or 4 piston calipers. They don't mention that the offset is different for any of the models shown.
    Bob
    30+ Posts
    Jan 2013
    Slidell, LA
    Quote Originally Posted by dmillsr3 View Post
    '96 Harley FXD, but I don't plan on using the stock frame for the build. I'm trying to determine the axle's sprocket offset to see if it correlates to the Harley's sprocket offset.
    Bob
  1. Need DNA rear axle dimension.
    By bobscogin in forum Home Built Trikes
    Last Post: 06-25-2016, 09:38 AM
  2. Axle question on VW
    By starrtrain in forum VW Powered Trikes
    Last Post: 03-17-2014, 07:14 AM
  3. Solid axle question
    By MangoMike in forum Honda Trikes
    Last Post: 07-10-2013, 08:13 PM
  4. Rear Axle Rigid Swingarm or 4 Link?
    By mutwagn in forum Home Built Trikes
    Last Post: 03-19-2013, 09:05 PM
