Likes Likes:  1
Results 1 to 5 of 5
Thread: car tire on rear
    Nov 2008
    Yakima Washinton
    Default car tire on rear
    has any one tried a car tire on the rear of the can am.
    Oct 2010
    USA
    Quote Originally Posted by 3wheelguy View Post
    Yes I have front and rear.
    5250+ Posts Pegasus1300's Avatar
    Spring City,Utah, USA
    Most everyone puts a car tire on the rear. The OEM tire is junk so if you want to improve the handling of your spyder add a car tire to the rear. When the fronts wear out put car tires there also.
    Happy TRAils/NSD
    Paul
    Nov 2008
    Yakima Washinton
    Default good to hear I was goiing to try. it helps to hear it been done before thanks
    Quote Originally Posted by Pegasus1300 View Post
    10+ Posts cyclekid58's Avatar
    May 2017
    Post Falls, ID USA
    Default car tire
    I run a General Altimax RT-43 in 215/60 15 at 23lbs pressure, most everyone I know has switched to a car tire after the stock kenda wears out. I have 15,000 on it and looks like new. No problems in wet or dry conditions. I also run car tires on the front, Federal EVO 595's stock size at 17lbs some are running the Federal Fomoza AD1 in stock size and like them real well. The kenda tires are crap, and there is better avail.
  1. Rear tire psi
    By GARYD in forum Harley Trike Conversions
    Last Post: 10-12-2015, 09:02 PM
  2. tire size for rear tire on front? 2007 goldwing trike
  3. Rear Tire Pressure
    By sonny8l3 in forum VW Powered Trikes
    Last Post: 10-16-2014, 12:25 PM
  4. Need some rear tire help!
    By flyby8906 in forum Honda Trikes
    Last Post: 07-22-2014, 09:10 PM
  5. Rear tire width
    By pigbike in forum Lehman Trike
    Last Post: 08-27-2013, 03:49 PM
