Cut N Shoot Customs2miaboboCut N Shoot CustomsGL1800 & GL1500 Fork Tube Exten...
LD-Ordie7ol' schoolNew Member Introduct...Newbie from the Mojave Desert
Rawhideken16KoolbreezeHarley Tri Glide2024 Tri glide
LD-Ordie7trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie7GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie7rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie7SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie7Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
Rawhideken16LD-OrdieHarley Tri Glide2024 Tri glide
LD-Ordie7LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  7
Results 1 to 12 of 12
Thread: Tin rattel
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    Default Tin rattel
    I have developed a engine tin rattel
    every time I think I have it fixed it starts rattling in a different place
    Its driving me nuts
    Thank you
    Bob
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    Default reply
    been 40yrs. since i worked on a vw.....but is it air flutter from driving at speed or mechanical? would try wedging material where possible....taping on mtl to isolate area....or is there a flapper in the fan housing that could vibrate or thermostat unhooked? anyhow good luck hunting!
    Sep 2014
    Moneta VA
    it only does it at a low idle (below 1000)
    above 1000 it is better
    and it does not do it all the time
    It does not have the thermostat fin.
    Yesterday I tracked part of it down to the cooling fan.
    I removed the belt and the back seat for i would have access to the fan.
    It spun around fine with nothing rubbing.
    The fan is on tight
    The alternator is strapped down good so I do not think its moving
    All my tins seem tight
    Some of the rattle is the chain I wrapped around the exhaust
    It looked so cool when I warped the chain around the exhaust but it has been a pain ever since.
    Will never do that again
    Thank you
    Bob
    "Tin Man" Doug D.'s Avatar
    May 2012
    Vienna, MO USA
    Mine's so loud I couldn't hear it rattle anyway.
    "The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility, it's right. If it disturbs you, it's wrong until either the machine or your mind is changed." - Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
    Sep 2014
    Moneta VA
    Quote Originally Posted by Doug D. View Post
    Maybe that's the way to go
    Blow out the exhaust and make it louder for I don't hear it
    or get a better stereo and turn it up loud
    Thank you
    Bob
  6. #6
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    What all tin do you have installed?
    I would also check the deflector tins between the cylinders on the bottom. They will get loose and rattle a lot of times. They just snap over the cylinder studs and can sure do that.
  7. #7
    50+ Posts Bugman's Avatar
    Aug 2010
    Blairsville, Ga. USA
    I had a rattle and found it to be a broken baffle in one of the headers.
  8. #8
    Sep 2014
    Moneta VA
    Quote Originally Posted by stinger608 View Post
    I forgot about those
    I will check them tomorrow
    I have the the dog house, cycle tins and the deflectors
    Thank you
    Bob
  9. #9
    May 2012
    Vienna, MO USA
    Dude, that is BADASS!!
  10. #10
    5+ Posts reverand2000's Avatar
    Mar 2016
    Cumming, Ga, USA
    Quote Originally Posted by Fowler View Post
    Must be a single man. Wife would never let the engine parts be in bedroom!
  11. #11
    Sep 2014
    Moneta VA
    Quote Originally Posted by reverand2000 View Post
    At that time the wife was visiting family
    Thank you
    Bob
  12. #12
    1+ Posts
    Aug 2017
    Trophy Club, TX, USA
    Quote Originally Posted by Bugman View Post
    I had the same experience.
