Likes Likes:  7
Results 1 to 8 of 8
Thread: Knock Sensor Removal
    900+ Posts
    Bellville, Texas, USA
    Default Knock Sensor Removal
    I have a friend with a 2001 GL1800. He needs to remove the knock sensors but he can not get the wire disconnected from either sensor. He says he has tried to pull it loose, used pliers and tried to pry it off with a screwdriver but he is afraid to get too aggressive with it as he is afraid he will break the wire connector or the sensor. Is there a trick to getting the wire disconnected from the sensor? He has tried both the left and right bank sensors but can not get either one disconnected.
    Thanks for any help.
    Sunman
    May 2011
    San Angelo
    Quote Originally Posted by Sunman View Post
    Sunman
    Howdy Danny... I'd bet there is a release on those connectors somewhere. Sort of like the one that connects the ignition switch dash part. That sucker has caused more grief then the law allows!! A dental mirror or something similar may be handy to have in this situation...
    2015 GL1800/Roadsmith HTS1800
    Jun 2008
    Lovington, NM, U.S.A.
    You have to remove parts to get to the 1p connector
    It's usually a tab to push down on and pull off. The circled piece is holding it in place and then once tab is lifted on the connector pull down, odds are there is a seal inside to keep water out. Red arrow point to seal.
    Need a service manual? There's one here for the GL1800: https://www.manualslib.com
    Retired trike builder
    900+ Posts
    Quote Originally Posted by Gold Rush View Post
    Hi Jerry. He is having fits with it. I will pass along the suggestion for the dental mirror, that might work.
    Hope to see you in October in Kerrville. We are signed up and looking forward to it since we missed last year but my mother is now 95 and not doing well so we are day to day on any plans.
    Sunman
    900+ Posts
    Quote Originally Posted by trike lady View Post
    Thanks Trike Lady! I will send this info to him. I don't know for sure if he has a manual or not. He has removed the tupperware to get to the sensor.
    Sunman
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Tell him not to pull on the wire. It is a shielded wire. As other have said, he must release the lock point on the connector, and then pull the connector down.
    Tricks: to loosen contamination between the connector and the sensor, try pushing up on the connector, and also spray it with BrakeClean (red can). If the lock point is pushed, after spraying it with BrakeClean, it should come off easily.
    The crew has U covered here good
    I would add to lube the terminals and the locking tabs and plastic shoulders in Trike ladys pics JMO
    This pic shows another view of a weather pak connector found on many vehicles up to and including ur trike, I hope this helps also
    900+ Posts
    Thanks for all of the responses! My friend advised me this morning that he found the release and was able to get both sensor plugs off with no problems.
    Thanks again!
    Sunman
  1. Knock, Knock...who's there?
    By rjbii in forum New Member Introductions
    Last Post: 10-10-2016, 10:51 PM
  2. Suspension knock
    By TG Bob in forum Harley Tri Glide
    Last Post: 04-24-2016, 06:55 PM
  3. Knock Count and the PV or Are my Pistons in danger
    Last Post: 05-23-2015, 03:24 PM
