Likes Likes:  8
Results 1 to 16 of 16
Thread: DK Custom Stealth LED Driving Lights
    1500+ Posts
    hardwickbv's Avatar
    Mar 2017
    Mitchell, Indiana, USA
    Default DK Custom Stealth LED Driving Lights
    Anybody running these on their High Beam.
    I have a set on the way and am debating on how to hook them up on my 2017 Trike.
    Bob
    Sep 2014
    Box Elder, SD
    Quote Originally Posted by hardwickbv View Post
    Bob
    I have the set up on my 14 year tri glide on the low beam. I plan on adding a dedicated switch for the stealth lights and I will be able to use on high and low beam. Jim
    50+ Posts
    Mar 2017
    Little Elm
    I think this product may be my next purchase . . . moving to the country in November . . . may come in handy on the East Texas country roads
    2014 TGU Black . . .
    1500+ Posts
    hardwickbv's Avatar
    Mar 2017
    Default After some more research
    My auxiliary/passing lights will only come on with the low beam and I wanted the driving lights to close up the holes on the sides when using the high beam.
    From what I have found in other threads I can have the dealer to FLASH my system to have the auxiliary/passing lights on all the time with both the low and High beam. The auxiliary/passing lights have a dedicated switch so I could turn them off if needed but I can't of a reason why I would want to do that.
    So if I get the auxiliary/passing lights to come on all the time then I will just hook the driving lights up to them which appears to be a much easier task than trying to hook them up dedicated to the High beam only.
    This way I will have the benefit of the driving lights all the time.
    Does this theory sound doable?
    Bob
    400+ Posts Recall's Avatar
    Jul 2013
    Winfield, WV, U.S.A.
    I recently installed these on my 2015 under the foot boards (stealth mode). Coming back from Panama City, FL. the daytime temps were floating between 98 and 100 degrees. I decided to run in home at night to beat the heat and rain forecast. Riding in the dark, on low beam, driving lights and led's, I had no reason to run my high beam. The leds put out enough light to give me coverage from shoulder to shoulder and beyond on the super slab and did not bother oncoming traffic. That is running 75mph and in some rain. Just my .02, but I think you would be fine with just adding the led on the low beam side. More than enough light to see everything from tree rats to bambi. Not to mention simple, clean and easy install. Thanks to DK for another great product.
    Dave
    2015 Tri Glide - Hot Pearl White/Blue
    82 FXR
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Bob
    That is what I do. If my aux lights are on, my Stealth LED Driving Lights are on. I have my bike flashed so that my aux lights can be on with my low AND my high beam.
    The only time I turn my aux light (and Stealth LED's) off is if I am in a parking lot with a lot of folks walking around, or at a rally with folks walking or sitting around.
    www.DKCustom.com
    1500+ Posts
    hardwickbv's Avatar
    Mar 2017
    Thanks for all the responses.
    Thanks Kevin for another great product.
    I am going down to Tennessee and North Carolina this weekend for a ride so I won't install them just yet.
    I will need to get the bike into the dealer to replace the Front Fender tip light that quit working last week so I will have the Flash it then and then install the lights.
    Is there an preferred/easy place to tap into the wire?
    Bob
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Bob
    The easiest place, that is also hidden, is on each side, behind the inner fairing skirt/dash panel fairing. This is the piece of plastic at the bottom of the inner fairing...the one your ignition switch sets on top of.
    The wires for the front turn signals and for the aux. lights sit right behind that skirt and are easy to access WITHOUT removing any part of the fairing.
    www.DKCustom.com
    20+ Posts
    Feb 2008
    Brookings, SD
    Will any dealer run a flash for your highway lights? How much should it cost to have it done?
  11. #10
    Sponsor
    TrikeTalk Sponsor
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by ljk View Post
    Every dealer should do it. It is a federal law that it is legal to run high beam and running lights. However, quite a few years back it was not.
    As recently as a year ago I spoke with a dealership that still did not know that the law had changed...there might still be some out there that are ignorant of the law change.
    They should not charge anything.
    www.DKCustom.com
  12. #11
    20+ Posts
    Feb 2008
    Brookings, SD
    Thanks for the information Kevin.
  13. #12
    50+ Posts
    Mar 2017
    Little Elm
    I have a 2014 TGU and will be adding the DK Stealth Lights on my engine guard. Do you know if the switch # 71400044 will work?
    I want an on/off effect with the lights. Adding a switch to the panel seems like the best option for the on/off capability.
    Thanks for any insights....
    Uncledoc
  14. #13
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Quote Originally Posted by uncledoc View Post
    Yes it will work.
    Nuc
  15. #14
    100+ Posts Rev J's Avatar
    May 2016
    NC
    Going to order my lights soon and looking at the wiring possibilities. If I tie into the wires you referenced are the lights going to come on when the aux. light switch is activated that came with trike? Or do I need an additional switch like the Harley aux power switch kit part# 71400106? Thanks, Rev.J.
  16. #15
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Quote Originally Posted by Rev J View Post
    The will be activated by the Auxiliary Light switch.
    Nuc
  17. DKCustoms postbit
  18. #16
    May 2016
    NC
    Quote Originally Posted by nucseal View Post
    Nuc
    Thanks for the info, Rev.J.
  1. ***DK Custom Products Stealth LED Driving - Passing Lights***
    By DK Custom Products in forum DK Custom Products
    Last Post: 08-21-2023, 09:26 AM
  2. Replies: 4
    Last Post: 09-06-2018, 02:03 PM
  3. ***DK Custom Products Universal Fitment - Stealth LED Run-Brake-Turn Lights***
    Last Post: 06-27-2017, 11:43 AM
  4. DK stealth lights install help
    By uppercaseJC in forum Harley Tri Glide
    Last Post: 04-18-2016, 09:15 AM
  5. driving lights and head lights
    By Dragon in forum Stallion Trikes
    Last Post: 10-05-2014, 09:25 PM
