LD-Ordie4rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie4SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie4LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  4
Results 1 to 7 of 7
Thread: 2008 GL1800 bad rear wheel bearings.
    30+ Posts
    Jun 2017
    Florence, Alabama, U. S. A.
    Default 2008 GL1800 bad rear wheel bearings.
    Took my trike to dealer today to have the brake recall done. Service manager called to tell me it was done but when they drove it they felt a vibration and when they checked found the rear wheels bearings bad. This has a RoadSmith kit. What I need to know is how hard it is to replace the bearings and are any special tools needed?
    Thanks Dannie
    Mar 2011
    mountain home,ar. USA
    1. Hubs are Volkswagen
    2. from owner's manual: Any full-service automotive repair facility can call us, toll free, at 800.331.0705 and we will be happy to answer their questions on how to service or repair the converted portion of the Trike.
    3. Call RS for support. They can verify and tell you what needs to be done.
    Good luck.
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Glad to hear the dealer was alert enough to catch it.
    30+ Posts
    Jun 2017
    Thought I would give a update in this. I ordered new bearings and seals from Rock Auto and when the arrived( I did not want to have the trike down while I waited on parts) I pulled the wheels and what I found was not bad bearings but the nut holding the stub axel was only finger tight. It is suppose to be tightened to at least 250 ft. lb. Did about a 60 mi. ride and things are a lot better.
    May 2011
    San Angelo
    Quote Originally Posted by 6adan View Post
    Thanks Dan!!! That is good news for you and the rest of us Roadsmith owners. I thought it strange the bearings went bad but that happens so I wasn't doubting it. I think that may become part of my winter maintenance/inspection schedule.
    2015 GL1800/Roadsmith HTS1800
    30+ Posts
    Jun 2017
    This had to be done by someone who thought they knew what they were doing, there were new carter pins in the axels. Might have thought it was done like a car front wheel is the only thing I can thing of as to why it was done that way.
    JustWings.com
    May 2016
    In their Owner's Manual thy list part numbers.
    http://www.roadsmithtrikes.com/media...-and-later.pdf
    Bearings: all VW applicationInner: #113-501-283
    Outer: #113-501-277AAxle seals: #113-501-315CV joints: #113-501-331
  1. Main bearings - GL1800
    By GoldWingrGreg in forum Honda Trikes
    Last Post: 03-25-2017, 06:50 PM
  2. Front Wheel Bearings?
    By BinIdaho in forum Harley Tri Glide
    Last Post: 05-03-2016, 10:43 AM
  3. 2008 GL1800 Motor Trike rear end
    By haddont in forum Honda Trikes
    Last Post: 08-29-2015, 05:29 PM
  4. Front wheel bearings
    By howardg in forum General Discussion
    Last Post: 04-25-2015, 03:38 PM
  5. Stallion Wheel Bearings/Hubs
    By gctrikeguy in forum Stallion Trikes
    Last Post: 10-21-2014, 09:30 PM
