ADSavarese8ol' schoolNew Member Introduct...New member from FL
ADSavarese8GorillaNew Member Introduct...New member from FL
ADSavarese8Marc HNew Member Introduct...New member from FL
ADSavarese8ADSavareseNew Member Introduct...New member from FL
ADSavarese8Phu CatNew Member Introduct...New member from FL
ADSavarese8trike ladyNew Member Introduct...New member from FL
ADSavarese8Uncle FesterNew Member Introduct...New member from FL
ADSavarese8rhino 2New Member Introduct...New member from FL
Likes Likes:  2
Results 1 to 7 of 7
Thread: Oil pressure question
    30+ Posts
    Aug 2016
    Fort Mill, South Carolina, United States
    Default Oil pressure question
    While rebuilding my 1970 dual relief 1600 I had the case full flowed and I am running a remote oil filter. I am running a larger oil pump but do not remember the exact size and I am running a manual oil pressure gauge. The problem is when I stop the oil pressure goes down to 0 for a few seconds this happens with both the stock and high pressure springs. Is this normal? should I be concerned?
    I am not familiar with the VW's enough to answer, but ?I'm sure one of the VW Guru's will respond soon ... so bump!
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Zero is not normal.
    10 psi per 1000 rpm is normal.
    So an 800 rpm idle should be 8 psi.
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    When you ran the tubing for the oil pressure gauge, did you make sure and bleed all the air out of the line?
    An air bubble may be causing that issue.
    Just pull the oil line, and your coil wire (so the engine doesn't start), then crank the engine over for a minute or two until you have solid oil coming out of the line.
    If that isn't the problem, then you have a serious internal oiling issue.
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    Default reply
    do you mean that oil pressure drops to 0 at a stop lite, but then recovers??? or mean it stays down to 0.....if it recovers to normal after a short interval, i would suspect a relief valve hanging up, then finally closing, and pressure returning to normal.... my 02 larry
    Quote Originally Posted by Doughboy66 View Post
    Any chance the problem is the remote oil filter...Holding back the oil flow till the pump can over ride it...VW Air cooled were never made with a oil filter , Or needed one...
    [Except for the wet air filter]
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Well that gives another thought.
    Not all filters are built the same.
    They all have a filter element.
    But some depending on application have a flow check valve so they don't drain back when shut down.
    Others have a pressure differential valve that bypasses the element if the filter is clogged or oil to cold and thick to pass through.
    All that being said.....it is possible to have the oil lines backwards on the in/out and cause all kinds of oil pressure problems.
    And personally I would recommend an oil filter over any other possible engine modifications.
  1. New wheel size now air pressure question
    By uppercaseJC in forum Harley Trike Conversions
    Last Post: 05-06-2016, 03:08 PM
  2. TPSM ?? or tire pressure system question
    By JaysGone in forum Honda Trikes
    Last Post: 01-28-2015, 07:18 AM
  3. tire pressure???? suspension pressure???
    By flangar in forum Stallion Trikes
    Last Post: 05-10-2014, 09:53 PM
  4. tire pressure on goldwings/trikes question
    By bumlbe in forum Honda Trikes
    Last Post: 02-03-2011, 10:20 AM
  5. tire pressure question-please
    By grampadonut in forum Tires, Wheels, Brakes, Front End
    Last Post: 07-21-2010, 07:24 PM
