Likes Likes:  2
Results 1 to 14 of 14
Thread: rear tire pressure
    Apr 2013
    MANNFORD,OKLA,USA
    Default rear tire pressure
    the roads in okla all crown to the outside. does anyone run a couple of pounds less air in the inner tire, if so how does it affect the trike normally?
    Mar 2011
    mountain home,ar. USA
    I use the same in both, 28-32 psi depending on load. Because I live and ride in the Arkansas twisties, I would rather have both tires the same so they behave identically through the turns. Personally, I don't seem to have a problem on most roads I've traveled with my trike from Arkansas to Nova Scotia and thought, "Gee, wish I had a couple of pounds less in that left tire". Besides, then I would have to remember they're not equal when I check the pressure.
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Instead of running different pressures in each rear tire, I recommend finding better, twister roads to ride where a rider would never notice a pull. For example, if you ride US129 (the Tail of the Dragon), my bet is you'd be so busy "slaying the dragon" that you'd never notice any pull/drift.
    http://tailofthedragon.com
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    Quote Originally Posted by nightstalker View Post
    I did for a while,but could not really feel any advantage in doing that. I run 22 in the rear and it feels good to me. 08wing/13roadsmith. My advice is search around for what suits you best. RIDE SAFE
    Jun 2010
    Indianapolis, In.
    I dampened my drive and aired up the rears to over 30psi. Kept running over the wet drive, letting air out until I left a full tread width track.
    Because my conversion is a Hannigan(off set rear to the right)I ended up at 24psi in the Left rear and 26psi in the Right rear.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    200+ Posts
    May 2013
    Mackinaw Il usa
    Default Avon trike tire
    Do you put dyno beads in them and how much pressure to you put in it cold?
    Apr 2010
    Shenandoah Valley of Virginia
    1997GL1500 / 1998 Lehman GTL ..... I run same 22-25 psi in both rears always. 22 light load, 25 two up towing 215/70-15 rear tires on 7x15 wheels.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    1997GL1500 / 1998 Lehman GTL ..... I run same 22-25 psi in both rears always. 22 light load, 25 two up towing 215/70-25 rear tires on 7x15 wheels.
    Do those 25" tires hold air on the 15" rims ???
    Jim Murphy
    Iron Butt Rider 2001
    Feb 2008
    Anderson, Missouri
    Most well traveled roads have slight ruts where the wheels of countless
    car and truck wheels have worn the pavement. I ride with the front wheel
    just to the left of the centerline, on the side of the rut. From the point of
    view of the front tire,"downhill" is to the left, and is pulled that way a bit.
    Different roads vary on how much of a valley there is, if at all, and I just
    have gotten used to steering against the pull of the crown of the road.
    100+ Posts RUMRUNR's Avatar
    Basehor, Kansas, USA
    Quote Originally Posted by GoldWingrGreg View Post
    Did the Tail of the Dragon twice last fall on my brothers trike with no rake. Do that ride 318 curves in 11 miles and enjoy the shoulder pain.
    Sep 2012
    Lakeland, FL
    Quote Originally Posted by mhgoldwing View Post
    Agree, think RoadSmith recommends around 28 psi, as mhgoldwing, I'm running 32 mostly riding two up.
    Apr 2010
    Woops, having some double vision problems. Fixed it,
    80+ Posts tbird71's Avatar
    Feb 2018
    Lake Placid, FL (winter) Ramsey, IL (summer)
    Greg I dont know about Goldwings but your avitar has THE nicest set of honey buns I think I've ever seen! Talk about "Well Rounded".
    Ride Safe!
    Tom
    2019 Tri Glide (Black with pins)
    2015 FLHTP Electra Glide Police (Black w/o pins)
    Quote Originally Posted by tbird71 View Post
    Tom : Greg hasn’t posted In almost two years…🤔..
    But yes on the Bun’s …👍
  1. Road Smith Rear Tire Pressure
    By bikerbillone in forum General Discussion
    Last Post: 10-16-2016, 12:39 PM
  2. What Rear Tire Pressure Do You Like On The Freewheeler
    Last Post: 07-18-2015, 07:11 PM
  3. Rear Tire Pressure
    By sonny8l3 in forum VW Powered Trikes
    Last Post: 10-16-2014, 12:25 PM
  4. Rear tire pressure
    By Phu Cat in forum Harley Trike Conversions
    Last Post: 11-14-2013, 05:11 PM
  5. Rear Tire Pressure
    By americanbadass in forum Tires, Wheels, Brakes, Front End
    Last Post: 05-08-2013, 05:20 PM
