Likes Likes:  7
Results 1 to 7 of 7
Thread: What kind of oil?
    Aug 2017
    Maysville
    Default What kind of oil?
    According to the paperwork I've got a 2009, 1600cc VW motor on my trike. I have no idea what kind of oil to use but was told it had to have zinc in it??. What about additives? Synthetic oil? etc. Also, it doesn't have a spin on filter but I was told I could get a kit to convert it. Any ideas where? I'm very new to this VW stuff.
    Quote Originally Posted by RedDirtFarmer View Post
    I used straight 30 Weight , But that was with a 65 dune buggy, And a 71 and 73 bug...
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    The problem with oils is that they have changed over the years. Epa rules and the needs of modern cars being much different than our old motors.
    You really need an oil formulated for a flat tappet mechanical solid lifter cam.
    That means zddp content.
    Zddp levels have been restricted low by epa.
    So anything correct for our motors is technically illegal to use on the street.
    There are specialty high dollar oils for older engines that you can order.
    The most available over the counter retail oil is Valvoline VR1 Racing.
    Stay as close to 30 weight as you can.
    If you have an old loose motor use a little thicker oil until you have sufficient pressure.
    1000+ Posts Rsw's Avatar
    Sep 2011
    Little Hocking, Ohio
    Add a little of this to your oil to get the zinc count up
    https://lucasoil.com/products/engine...e-tb-zinc-plus
    20+ Posts
    Jul 2017
    NORWICH
    Default Recommended oil
    I use Quantum Platinum 5/40 fully synthetic in my 1600 air cooled. When I bought it the previous owner had used some type of oil that emulsified in the oil filler cap area. Since using Quantum I've had no problem at all. The Quantum was recommended by a place that works on aircooled VW's all the time.
    Aug 2017
    Maysville
    After a lot of googling I ended up with Valvoline VR1 20W-50 racing oil which has the maximum amount of zinc already in it. I ordered some Shaeffer oil that was recommended and I bought a bottle of zinc additive but I think I'm good for now.
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    That's an excellent choice of oil!! That is the exact oil I've been using and haven't had a single issue.
  1. Be Kind To Others
    By David357 in forum General Discussion
    Last Post: 03-14-2017, 01:37 PM
  2. What kind of trike
    By ironhorse446 in forum Enabled Trikers
    Last Post: 04-07-2015, 06:12 AM
  3. Kind of new here...........
    By Keystone in forum New Member Introductions
    Last Post: 07-18-2010, 07:05 AM
