Likes Likes:  3
Results 1 to 8 of 8
Thread: Higher ratio crown wheel and pinion
    20+ Posts
    Jul 2017
    NORWICH
    Default Higher ratio crown wheel and pinion
    Does anybody have information about an alternative C&P for a 1600 aircooled.?
    Apr 2015
    Batesville, AR. 72501
    Check out the Tech sticky thread: http://www.triketalk.com/forum/threa...-build-a-trike on page 5 Rex discusses R&P configs.
    The Samba is a good VW site for all things VW: https://www.thesamba.com/vw/
    You will need to start with the serial # of the transaxle to determine what you have now. This is assuming that it has never been modified, a rare creature these days.
    Spend some time reading the older posts here and you will pick up a lot of info. The R&P issue has been discussed in the last year.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    My tech thread is a bit messed up.
    I will jump over there and fix a few pics so it makes sense.
    Ok so as far as R&P goes there were 3 different ratios in common use in the USA.
    61 to mid 66 with 4.375 and swing axles.
    Mid 66 to 68 with 4.12 and swing axles.
    Then the 69 and up IRS double side cover with 4.12 ratio
    The last few years was a single side cover with 3.88 final gear. But 4th was lower. Same rpm on highway but bigger 1,2,3
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    So which trans do you have?
    The marketing term "freeway flyer" is not a certain definition......more of a deception.
    But in a very general way it means an up geared box. Typically made from a combination of stock parts.
    So if you are looking you must ask all the right tech questions so you know what you are getting.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    By far the most common thing to do is get a 67 up 4.12 geared trans and put tall tires on it for the up gearing.
    Then there is me...... I changed a lot of gears in mine.
    https://weddleindustries.com/product...pe-1-gearboxes
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    For the last couple years I have used Rotella T6 in the colder months and 20/50 in the warmer months
    (don't remember the brand but i Make sure it has a higher number on the ZDDP)
    I add a ZDDP additive also. Again don't remember the brand
    I looked it up and i do not think I am overdoing the ZDDP
    Thank you
    Bob
    1000+ Posts Rsw's Avatar
    Sep 2011
    Little Hocking, Ohio
    I had a IRA trans built for my swing axle using a 3.88 R&P and a .082 4th gear. The .082 is out of a bus and higher then the standard IRA 4th gear. I believe that is the highest combination you can make using stock parts.
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Yes basically it now a days.
    There was one other 4th, but rare to find.
    You can swap a lot of parts around in a double side cover case, early or late.
    Most (like above) are the same 1st and 2nd
    The diff unit that the ring bolts to is different.
    Early had a 6 bolt crown.
    At 67 they went to an 8 bolt.
    Here in the states if you want to convert an irs to a swing you need a diff from a 67 or 68 box.
    In Europe and other countries they had the swing much later in years.
    And odd engine combinations.
    The late swings from there are probably 8 bolt.
  1. Lehman Pinion Seal
    By durango9 in forum Lehman Trike
    Last Post: 03-21-2017, 05:43 PM
  2. ring an pinion
    By ALBEE1947 in forum Honda Trikes
    Last Post: 08-20-2013, 06:44 PM
  3. Newbie 07-09-13 Crown Royal Kid
    By CrownRoyalKid in forum New Member Introductions
    Last Post: 07-10-2013, 06:42 PM
