Results 1 to 5 of 5
Thread: Why no Stage II torque for the trikes
    10+ Posts AZFrosty's Avatar
    Jun 2017
    Buckeye, AZ, USA
    Default Why no Stage II torque for the trikes
    Yet it fits all of the other touring models. It seems like the trikes could use it the most. Anyone know why?
    1000+ Posts
    Aug 2016
    Des Moines IA US
    I'm no expert but I would say the weight of the trike verus the 2 wheeler and the gearing more than likely plays into it also, you have 2 big tires back there to pull it down the road.
    If not happy with what you have, you can always go to the 120 motor from harley, a few on here have it and are very happy with it and the power it has.
    All for now Trampas
    400+ Posts
    Jan 2015
    Barrington, NH USA
    It may be due to the kit has not been approved for a trike by the EPA.
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Quote Originally Posted by AZFrosty View Post
    Prolly what NHBagger said.
    You could do a Performance Plus Stage I, save some money, and probably end up with more torque than you would from an HD Stage II Torque upgrade.
    www.DKCustom.com
    600+ Posts 427dave's Avatar
    Jan 2011
    The Villages, FL
    Quote Originally Posted by Trampas View Post
    All for now Trampas
    I installed 120 ST. Lots more torque, on the Dyno 130 ft lb torque and 118 HP. This with stock mufflers.
    Rear lift kit, and tour pak relocation, Road Zepplin Air seat, Chrome front forks, SE 120 ST engine, Headers by V&H, Stock mufflers, SE 259E cams, TTS tuner and SE Air Cleaner, 58 mm Throttle Body, Tank lift, Wind Deflectors, DIY Crankcase Breather, Floorboard Ext.
    Amateur Radio : W4WNG
  1. Cams vs torque and hp/?
    By T.P. in forum Harley Trike Conversions
    Last Post: 06-25-2015, 09:07 AM
  2. need more torque
    By captdanwh in forum General Discussion
    Last Post: 07-30-2013, 12:46 PM
  3. lug nut torque
    By geraldlanc in forum Honda Trikes
    Last Post: 05-16-2012, 06:53 PM
  4. torque cones
    By pcmikey in forum Harley Trike Conversions
    Last Post: 12-12-2011, 04:26 AM
  5. Lug Nut Torque Value
    By motorman7 in forum Harley Trike Conversions
    Last Post: 07-24-2009, 06:59 AM
